Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Tweety911's Avatar
Push button ignition 1971 911
Anybody ever wired up a push button ignition before? I want to have a switch for the starter (Push button) and want to have a separate switch for the fuel pump/ignition system. Totally get rid of the key (car is track only. No street). I do have an ignition cut-off switch already.
Old 02-21-2010, 03:45 PM
Walt Fricke's Avatar
Sure. My track car has this. I have an ignition switch, a fuel pump switch, and a push button starter switch. These parts are all easy to come by in heavy duty versions.
The fuel pump switch (car is carbed) is protected by one of those flip up switch covers you see on warplanes and such. Only I reversed the switch so that when the cover is down the pump is on. No chance of shutting it off accidentally (you can guess what led me to do this), but when I want ignition but no pump (for testing this or that) I can do it. And if I want to check the position on the grid when all buckled in, HANS on, etc., I can just feel with my gloved hand that the cover is down. Don't have to remember if on is up or down or whatnot.
Cut a piece of aluminum (round or square) to cover the ignition switch hole in the dash and then some, and rivet in place over the hole. Drill for your new ignition switch.
Wiring is dead nuts easy.
When I got my car as a roller, it still had the old ignition switch. I just left the key in it, but got to thinking what if: what if some prankster swiped the key at night at the track?
Plus simplifies things, less to go wrong, and a bit less weight.
Old 02-21-2010, 04:53 PM
Tweety911's Avatar
Yea, That was my plan. I have the ignition assembly out but I do not know which wire goes to what. So I need to know which wires go to Starter, Ignition, Fuel pump or a good way to figure it out.
Old 02-21-2010, 05:18 PM
Super Moderator
cstreit's Avatar
Pretty simple. Longacre makes some nice switch kits. Use a relay to power the important bits like lights, fuel, ignition.
This switch can be mounted in a plate covering your old ignition switch:
This longacre model I've installed in the left guage hole (removed fuel level guage):
You'll need a high capacity relay and have to undertand the wiring diagram for the ignition switch. There are quite a few so take your time and label all the wires carefully. Test them before you permanently wire everything.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 02-21-2010, 07:01 PM
Tweety911's Avatar
Anybody have some sort of diagram that explains which wire is what on the factory ignition switch assembly?
Old 02-21-2010, 08:29 PM
Sure - easy to find. For instance, our host Pelican Parts has nice 911 wiring diagrams on its website. You can find them easily.
Old 02-21-2010, 09:31 PM
Super Moderator
cstreit's Avatar
Here you are. Legend and more info found here. You're looking for circuit 31
Pelican Parts - Porsche 911 Parts Listings & Diagrams
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 02-22-2010, 06:12 AM
