Distributor Mods when fitting Webers on 82 ROW SC
Hi
What Distributor Mods are needed on a ROW 911 SC 1982 when fitting 40 mm Webers, Ie advance / Vac advance, Any advise would be great. Thanks John |
recurve
Kyle 1980 911sc 3.2 Turbo, 930 Trans 2006 BMW 330i 6mt (DD) |
Probably just a good servicing, I believe the ROW had a curve like the early 78-79 US SC's. Perhaps jsut a good cleaning following Gunters thread.
If it is not operating correctly and you are not getting full advance then you may want to get it serviced in curved. Just FYI - People are spending upwards of 650 for a recurve and recondition that takes about 12$ worth of parts and about 2 hours of work.
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS |
hi i have found that the ROW Dist has a near perfect curve all in by 4k
Great i am testing the car on the track on Friday Thanks |
John,
How much total advance are you getting at "all-in"? and what is your initial setting at idle? I don't have the specs in front of me but I think you should be getting 32-35 degrees total advance when it is set at 5-7 degrees at idle (950 rpms).
78’ SC 911 Targa - 3.2SS, PMO 46, M&K 2/2 1 5/8” HEADERS, 123 DIST, PORTERFIELD R4-S PADS, KR75 CAMS, REBEL RACING BUSHINGS, KONI CLASSICS Last edited by snbush67; 05-16-2011 at 12:11 PM.. |
