935 re-enforcement?
I'm planning on modifying my suspension to 935 type. I'm curious of the re-enforcements I should do to my chassis? I already have the rear shock tower bracing (bought from Elephant Racing). But I've also heard of people strengthening up around the 4 rear spring plate bolts, front 3 control arm bolts....
Can someone give me some more detail.... Thanks.
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com Last edited by armandodiaz; 06-04-2013 at 04:18 AM.. |
Would love to details also. My cars been upgraded to 935 control arms and the front is butchered by someone who wanted to extend a roll cage around the fuel cell. Ive been meaning to fix this and wondering about the same thing. ( My car is a prject and not on the track yet ). The rear in what I have is all custom fabbed and looks good, its the fron control arms Im most cusious about.
theamsoilguy@hotmail.com |
Max Sluiter
The main thing to understand is that you are changing the load path for the spring forces. Instead of torsion into the reinforced bits of the floor pan, the load is now going into the damper mounts which weren't really designed for it. They should thereforce be reinforced. The other mounts should be fine
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Can you or anyone else post any pictures of the re-enforcements? Right now my car is stripped to bare metal. It's the perfect time to weld any re-enforcement, weather it needs it or not.
Thanks,
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com |
Butchered front that needs work, worst welds I have seen in my life when this was added.
![]() The rear of my car is pretty custom so I dont know if it will help. There are many threads of shock tower reinforcement that show pictures. I would suggest you look a bit for those as thats what most do at a minimum. I have came across those threads many times. ![]()
Racer
Race cars or cars with cages?
Schleprock
Not a bunch of pics in this thread Rear crossmember, tower damage pics (from coliovers) but some good discussion. Also a good indication of what can happen when you don't reinforce the rear shock tower.
Kevin L '86 Carrera "Larry" |
So is this the bar that reinforces the front? Can you show me a picture of where you welded it to the floor pan?
Racer
Armando,
I don't have access to my car right now so I can't get that photo for you. I can say that the bar terminates in at the very front of the car beyond the front a-arm mounting point. This photo is somewhat helpful: ![]() The intent of the bar going to the front is to offer more crash protection and some stiffening. It is not to support the a-arm mount. Scott |
i am planning to run 800# springs in the rear of my build.
Here's a picture of what I did to brace my towers. ![]() If you have facebook, the pictures are all posted here. https://www.facebook.com/media/set/?set=a.1445964306944.2064710.1168236990&type=3 I already have Scotts car bookmarked so i can run my oil lines when I get to the oil tank... |
I used the Elephant racing bracing...
Racer
Mine:
![]() Scott |
Don't start giving me any new ideas. I'll never finish.
Schleprock
Scotts rear suspension structure is the hot setup. Provides a nice connection for the coilovers and ties into the chassis very well- connects to frame rails & tub sheetmetal with a LOT of contact area. Choice of rectangular tubing is smart, to make installation simpler & clean.
Do the rear legs on Scott's structure help to support the engine mounting points? I have seen the motor mount gussets cracked on some long time racecars. Seems like a good idea to get some additional strength back there. Scott needs to get his car back so we can see some more!
Racer
If you take some strength away, it is good to add some back. Scott |
Super Moderator
You actually race this piece of jewelry? Too darn fine for beating on!
Scott do you any post with more pics? Like to see what other ideas I can get.
Racer
Here's a link to my build...
Project GT2 is underway! Notice I started it in 10/2006. Hoping to get some paint on it by the end of the year.
Armando Diaz 85 911 Carrera - Track car 01 996 Carrera - For Sale http://forums.pelicanparts.com/showthread.php?s=&threadid=327823&highlight=996 87 944na - Old Daily Driver, now 944 CUP 03 Chevy Avalanche- Support Vehicle 70 Olds 442 W30 Conv- Gone but not forgotten http://www.diazracing.com adiaz@diazracing.com Last edited by armandodiaz; 06-05-2013 at 03:21 PM.. |
