LinkBack | Thread Tools | Rate Thread |
History qn: When did Porsche 911 Rear Control Arm Pivot Boxes first appear?
Trying to determine the year when Rear Control Arm Pivot Boxes (see pic) started being used?
Did 3.0RSR's have them? 934? 935?
Cheers, Ryan 1969 911E (historic racer) 911ST replica (tarmac rally) |
It's possible that Kremer used them when they used coil overs on the early RSRs
AM
1970 911E - track / weekend car 1970 911S - under restoration 1986 930 Slant Nose - fun car |
Thanks Andrew, so would this be about 73 or 74?
Racer
Is this a vintage racing period correctness question?
Scott |
The coilovers were in 73, and it's not out of the question the brothers experimented with the boxes around the same time.
Max Sluiter
I always thought those were aftermarket items from maybe the late 80's or early 90's.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Max Sluiter
Looks like they go back to the 935. I don't think the RSRs ran in classes that allowed moving the pickup points from their homologated positions.
![]() Porsche 934.5 Brumos Racecar_ 057 by Max_911S_fahrer, on Flickr
Racer
I don't think the RSR ever had them because you would need to raise the outer pickup points if you were raising the inner pickup points. The 935 ended up with adjustable out and inner pickup points. I am not sure if the 934 had them. But, as you can see from the picture Mac provided, the 934.5 did.
Scott |
Navin Johnson
I looked through some documentation I have, a few out of print books, etc..
It appears Porsche first raised the rear pick ups for the 935/78 when they raised the floor of the car flipped the transmission, there are indications the the 935 baby had modified inner pick ups..All references prior (RSR) to that mention moving the pick up to the rear to use with fabricated swing arms... And coil helper spring were available for the rear in Ti for DM 1000 ![]() I have been underneath a real 935, and it did not have an adjustable pickup like the one pictured, they just welded some extra material above the original pick-ups and drilled holes where needed
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others Last edited by TimT; 09-07-2012 at 07:54 PM.. |
Racer
Scott |
Max Sluiter
I think they may have moved up a few mm's on the 930.
Navin Johnson
The 930 used the RSR ( racing iterations) pickup points, out and back, according to Boschen-Barth.
Every resource I have available has no mention of raising the height of the pick up points until the cars got lowered extremely flipping the trans etc...77-78 I wonder if what the privateers did compared to the factory matters to a vintage racing org?
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Thanks guys, I'm looking into this wrt the potential purchase of a historic race car that has these parts fitted. The car was raced, and upgraded, from the late 70's to the late 80's. I'm trying to work out when this change was made and thus whether or not I would need to remove these parts for a particular class.
Racer
As I said, the 930 did receive that change. The inner pickup points were moved up 10mm. The outer pickup points remained stock. Anderson says it was for anti-squat. Others here suggested it was something else which I don't recall.
Scott |
Tired Member
Perhaps this is a question for Grady?
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
