Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
History qn: When did Porsche 911 Rear Control Arm Pivot Boxes first appear?
Trying to determine the year when Rear Control Arm Pivot Boxes (see pic) started being used?
Did 3.0RSR's have them? 934? 935?
Cheers, Ryan
1969 911E (historic racer)
911ST replica (tarmac rally)
Old 09-06-2012, 05:40 PM
andrew15's Avatar
It's possible that Kremer used them when they used coil overs on the early RSRs
AM
1970 911E - track / weekend car
1970 911S - under restoration
1986 930 Slant Nose - fun car
Current used parts for sale
Old 09-06-2012, 06:21 PM
Thanks Andrew, so would this be about 73 or 74?
Old 09-06-2012, 06:29 PM
Racer
winders's Avatar
Is this a vintage racing period correctness question?
Scott
Old 09-06-2012, 06:49 PM
andrew15's Avatar
The coilovers were in 73, and it's not out of the question the brothers experimented with the boxes around the same time.
Old 09-06-2012, 07:11 PM
Scott
Yep
Old 09-06-2012, 07:30 PM
Max Sluiter
Flieger's Avatar
I always thought those were aftermarket items from maybe the late 80's or early 90's.
Old 09-06-2012, 07:43 PM
Max Sluiter
Flieger's Avatar
Looks like they go back to the 935. I don't think the RSRs ran in classes that allowed moving the pickup points from their homologated positions.
Porsche 934.5 Brumos Racecar_ 057 by Max_911S_fahrer, on Flickr
Old 09-06-2012, 07:45 PM
Racer
winders's Avatar
I don't think the RSR ever had them because you would need to raise the outer pickup points if you were raising the inner pickup points. The 935 ended up with adjustable out and inner pickup points. I am not sure if the 934 had them. But, as you can see from the picture Mac provided, the 934.5 did.
Scott
Old 09-06-2012, 08:06 PM
Navin Johnson
TimT's Avatar
I looked through some documentation I have, a few out of print books, etc..
It appears Porsche first raised the rear pick ups for the 935/78 when they raised the floor of the car flipped the transmission, there are indications the the 935 baby had modified inner pick ups..
All references prior (RSR) to that mention moving the pick up to the rear to use with fabricated swing arms...
And coil helper spring were available for the rear in Ti for DM 1000
I have been underneath a real 935, and it did not have an adjustable pickup like the one pictured, they just welded some extra material above the original pick-ups and drilled holes where needed
'69 911 GT-5
'75 914 GT-3
and others
Old 09-07-2012, 07:48 PM
Racer
winders's Avatar
Originally Posted by TimT View Post
It appears Porsche first raised the rear pick ups for the 935/78 when the raised the floor flipped the transmission, there are indications the the 935 baby had modified inner pick ups..
The raised pickups were really needed when Porsche started using that 19" rear tire. The car had top be lowered massively to get the cg back down where they wanted it. This, in turn, required raising both the inner and outer pickup points significantly to get the roll center back up where it needed to be and to get the suspension to operate in the correct range under bump and rebound. The transmission was flipped to get the axle angle back to something reasonable.
The RSR got a shorter trailing arms that required the inner mount be moved out from center about 25mm and rearward about 48mm. The height wasn't changed though. The 930 received that change but neither car had a raised outer pickup point.
Scott
Old 09-07-2012, 08:13 PM
Max Sluiter
Flieger's Avatar
I think they may have moved up a few mm's on the 930.
Old 09-07-2012, 08:35 PM
Navin Johnson
TimT's Avatar
The 930 used the RSR ( racing iterations) pickup points, out and back, according to Boschen-Barth.
Every resource I have available has no mention of raising the height of the pick up points until the cars got lowered extremely flipping the trans etc...77-78
I wonder if what the privateers did compared to the factory matters to a vintage racing org?
'69 911 GT-5
'75 914 GT-3
and others
Old 09-07-2012, 08:52 PM
Thanks guys, I'm looking into this wrt the potential purchase of a historic race car that has these parts fitted. The car was raced, and upgraded, from the late 70's to the late 80's. I'm trying to work out when this change was made and thus whether or not I would need to remove these parts for a particular class.
Old 09-07-2012, 09:18 PM
Racer
winders's Avatar
As I said, the 930 did receive that change. The inner pickup points were moved up 10mm. The outer pickup points remained stock. Anderson says it was for anti-squat. Others here suggested it was something else which I don't recall.
Scott
Old 09-07-2012, 11:49 PM
Tired Member
DaddyGlenn's Avatar
Perhaps this is a question for Grady?
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 09-08-2012, 05:57 AM
