Better in Person
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
Automotive Writer/DP
1972 S - Early S Registry #187 1972 T/ST - R Gruppe #51 http://randywells.com http://randywells.com/blog |
Thanks guys! Awesome discussion. The more I research, the more I am afraid. I should probably just get a simple set up and save the headaches.
In my humble opinion, when go to a trackday the drivers with lots of bells and whistles on their cars isn't the fastest...
With limited driving time and experience I think one setting is enough. And as Winders said, high/low speed compression has nothing to do with the speed of the corner.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
1. They ARE worth it if you use them, which means adjusting the shocks at every different track including adjusting for temps conditions... 2. Custom valving will match the shock for spring rate, the JRZs will just add adjustability. 3. I have revalved Bilsteins on my 964s they have worked well for a long time with little maintenance, my motons have had several thousand in maintenance. They do not have the same scrapers and covers that a street car shock (Bilsteins) has. 4. Unless you spend the time to test and tune you will not set the benefit of the money spent on JRZs. 5. As a novice $4500 in coaching will produce lower lap times than shocks ever will...
2001GT3Cup/93RSA/944Spec#19 |
Thanks for the feedback guys. I have went ahead ordered custom valved RSR Bilstein and matching torsion bars from Steve@rennsport. Money saved from JRZs is getting me a set of 930 brakes i will most likely need.
I think you made a right decision to go with Bilsteins. I noticed on the JRZ front struts the diameter of the shaft is much smaller than Bilstein. So the JRZ may wear out quicker than Bilstein. Correct me if I'm wrong, guys. Maybe it's not an issue.
MikeD '87 930 |
