Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
Retired, finally
SiberianDVM's Avatar
Need suspension advice
This is my 84 Targa at CMP DE last weekend.
I have had the car 10 months. Replaced all the brake components, replaced front shocks with Bilstein HDs, rears with Bilstein Sports, lightened a bit, turbo tie rod ends, front strut brace. Haven't replaced any bushings, torsion bars, or sway bars yet.
I'm not happy with the amount of roll I'm seeing and feeling.
Suggestions to control the roll? I'm thinking torsion bars are next, and Elephants rubber bushings while I'm in there. Is that correct, and if so, what size torsion bars for a 90% track car?
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 10-31-2012, 01:04 PM
Racer
winders's Avatar
22mm front and 31mm rear torsion bars. Get Tarrett Adjustable anti-roll bars front and rear as well.
Scott
Old 10-31-2012, 01:11 PM
Racer
winders's Avatar
Then get the car lowered and corner balanced by someone that knows what they are doing.
After that, drive. Repeat.
Scott
Old 10-31-2012, 01:18 PM
Northern Motorhead
wildcat077's Avatar
Looks like you would have even more roll if that oversized instructor wasn't sitting in the passenger seat ... lol
Just like Scott says... been there still doing it
There is no end to improvements !
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 10-31-2012, 07:32 PM
Chuck Moreland's Avatar
Stiffer torsions, shocks custom valved to match, adjustable sways, lowered, raised spindles if the rules allow. If it's 90% track, don't go with rubber bushings - go Polybronze for sure. 23/31 torsion bars. Call if you want to talk specifics.
Chuck Moreland - elephantracing.com - vonnen.com
Old 10-31-2012, 09:58 PM
Max Sluiter
Flieger's Avatar
Well, your first problem is you are tracking a Targa.
Old 10-31-2012, 11:35 PM
michael lang's Avatar
After you replaced the tie rods and the shocks, did you have the alignment done? Did you have the car lowered? When the shocks were replaced, did you notice the ride height raise? My suggestion would be before you start throwing tons of cash at the car, is to start there. Get the car lowered and properly aligned and balanced. Once you have that as a correct starting point, don't touch the car. Spend the entire next season on maintenance, safety equipment and driving at DE's. Get to know your car and what you can and can't do with it. I will go on record as saying that I agree with everything everyone suggested about upgrading. Believe it or not one of the best modifications that I did to my car was putting in seats and harnesses. The reason is that I could focus on driving and not have to worry about holding on while I'm trying to drive. Remember, if you can drive a slow car fast, you can drive anything fast and if your instructors haven't already told you this, I would recommend you get one that has a car like yours. They will show you the correct way. Best of luck to you.
Mike
'89 CARRERA
#402
Old 11-01-2012, 12:49 AM
River Rat
Dave 86 930 Fl's Avatar
Talk to chuck at Elephant, I did some 3 years ago and I've been a happy camper since. Lots of experts out there, make sure you are dealing with one
Regards, Dave
1986 930 - K27-7200, Andial Intercooler, Tial Wastegate, Electronic Boost Controller, B&B headers, Bodart Zork, Leask Adjustable WUR, Full Elephant Racing Suspension w/Adustable Spring Plates and Von Shocks, Wevo Transmission Mounts, Fuel Safe Fuel Cell, Forgelines (9"/11"), Hargett Shifter, Innovate AFR, Cobra CF Seats, DAS Rollbar, Coleman Floating Rotors, Lightweight Interior, Forgeline 17" x 9"/11", 2800 lbs.
Old 11-01-2012, 02:22 AM
Retired, finally
Gotta dance with the girl I brung.
I did adjust the front ride height after the shock install and weight reduction; I measured the rear and it wasn't too bad, so after looking at the Rube Goldberg rear height adjustment Porsche installed, I left it alone for now. I will remeasure front and rear height after I install the roll cage.
Front toe-in alighnment was done after shock and tie rod installation; that was all I could get done locally. Car tracks very well, just rolls in the turns. After some more work is done, I will trailer her to Autometrics in Charleston or Franz Blam near Atlanta.
I got my shocks from Chuck, so I will give him a call.
My instructor was tall, but skinny. My weight more than balanced his.
Old 11-01-2012, 04:31 AM
Northern Motorhead
wildcat077's Avatar
Quote : My instructor was tall, but skinny. My weight more than balanced his.
OK,so it looks like he's wearing a big a$$ helmet ... lol
Cheers !
Phil
Cheers
Phil
Old 11-01-2012, 05:51 AM
ERP is the way!!!!
I did the complete package from Chuck at ERP this past winter its a relatively moderate diy project ERP and Chuck were extremely helpful .. also see a number of very good detailed threads here on installation. i did ASPs, 21/32 tbars polybronze everywhere. tarret adj bars. raisedv spindles decambered ball joints...this is THE BEST BUCK you can spend on an early race car build its also fine on the street etc etc... car handles flat as can be not a hint of body roll. game changer for sure in terms of your racing skill development. just my 2 cents frank
Carrera Suspension Update
search "trog"
Old 11-01-2012, 06:52 AM
River Rat
That's the right attitude ... A good friend and DE instructor has a twin turbo targa with 500 whp and he kicks some serious A$$. Let's face it, tracking a street car is a compromise, so have fun with what you have.
Old 11-01-2012, 02:12 PM
914 Geek
Consider reinforcing the rear ARB mounts. They are definitely known to tear loose from the chassis, particularly when tracking a car with stiffer Anti-Roll Bars.
--DD
Old 11-01-2012, 02:42 PM
Retired, finally
--DD
I'll check the brackets next time I'm under the chassis. What is the best way to reinforce them?
Old 11-01-2012, 06:10 PM
River Rat
Quote de Dave at Pelican Parts
--DD
Have a good shop cut the old junk brackets off and weld in aftermarket brackets. I did this mod, it's a must do
Old 11-01-2012, 06:22 PM
burgermeister's Avatar
A set of adjustable ARBs (Tarrett, SRP) will eliminate more roll that the torsion bar change. For instance, switching my 88 from 19/25 to 22/29 resulted in maybe 0.3 deg less roll, based on some fairly detailed calculations. Using ARBs got me almost 1 degree less roll without going to silly settings. I'd do both TB and ARB for a track car - doing just one makes little sense.
I'm always impressed at how people can feel the amount of roll in a car - I sure can't feel the difference between 3 and 4 degrees, which is pretty substantional. But your tires will tell you - if you're frying the outside shoulder, you don't have enough negative camber, and once your alignment is bottomed out, reducing roll is one of the easiest ways to get more negative camber (actually, less positive camber) while cornering.
'88 Coupe Lagoon Green
"D'ouh!" "Marge - it takes two to lie. One to lie, and one to listen"
"We must not allow a Mineshaft Gap!"
Old 11-03-2012, 12:12 PM
Automotive Writer/DP
Randy W's Avatar
It looks like your car is too high. Once you lower the roll center you should be much better off. Personally, I would not put huge torsion bars on a Targa. Been there, done that.
1972 S - Early S Registry #187
1972 T/ST - R Gruppe #51
http://randywells.com
http://randywells.com/blog
Old 11-03-2012, 01:22 PM
Racer
winders's Avatar
The Targa I used to own handled incredibly well and it had 22mm front and 31mm rear torsion bars......
Scott
Old 11-03-2012, 03:27 PM
914 Geek
I can vouch for that. At least, it looked like it from the outside. And from checking the event results.
Hey--I thought that was your wife's car?
--DD
Old 11-03-2012, 05:57 PM
Astroman's Avatar
Originally Posted by Geneman View Post
I did the complete package from Chuck at ERP this past winter its a relatively moderate diy project ERP and Chuck were extremely helpful.
ERP is not Elephant Racing (Chuck). ERP is ERP:
ERP Suspension Engineering Porsche
Jack
E class '87 911
Old 11-03-2012, 07:59 PM
