Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Brakes seem weak
My 2005 Cayenne S just does not seem to grab when I hit the brakes. Especially the initial braking action. I'm used to my other Porches having a good first bite when I hit the pedal. It takes a lot of pressure to engage ABS. Is there a pad with good first bite. Thanks
Old 07-18-2018, 02:03 PM
Administrator
Dmitry at Pelican Parts's Avatar
One of my colleagues also has a Cayenne S and mentioned the same thing about not getting that first good bite - seems like it's a 'Cayenne thing'. As far as brake pads, Hawk HPS pads are excellent if you're looking for something a bit more aggressive - link below.
https://www.pelicanparts.com/catalog/SuperCat/1078/POR_1078_BRKPRF_pg1.htm#item0
Old 07-18-2018, 03:27 PM
Send a message via AIM to fintstone
It is a very heavy vehicle. That said, the larger brakes on Turbo models stops them like a Porsche. It seems like they were optional on non-turbo cars...so one might find a set in a junkyard if their car is no equipped. I tried/test drove both models and the non-turbo versions seem more like driving a big station wagon as compared to the turbo (so I personally bought the turbo version more for handling/braking).
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 07-27-2018, 07:52 PM
It'll be legen-waitforit
stealthn's Avatar
When was the fluid changed?
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 07-29-2018, 07:29 AM
I've used HPS pad and I like them, however the weight of the car is certainly a factor. Pads/rotors lasted a long time for me, surprisingly even with a lot of towing. I'm changing them this weekend again, last change was about 5 years ago.
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 01-18-2019, 11:01 AM
