Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Uneven front tire ware 2010 cayenne s
My tires are less than a year old. The inner 1/3 portion of both front tires are worm to the indicator. What parts need to be replaced to correct this. I have 135 k miles on the car
Old 12-28-2020, 05:19 PM
honerboys's Avatar
hard to say - might just need an alignment - did you get one when tires were new? - was it done correctly? - try a different alignment place - they will probably be able to tell you if and what parts are worn - i burned a set of new tires off in 6 months because of a faulty alignment
84 928 S - SOLD
2012 Cayenne S
Old 12-29-2020, 07:42 AM
[QUOTE=honerboys;11159015]hard to say - might just need an alignment - did you get one when tires were new? - was it done correctly? - try a different alignment place - they will probably be able to tell you if and what parts are worn - i burned a set of new tires off in 6 months because of a faulty alignment[/QUOTE
Will start w alignment thanks
Old 12-29-2020, 08:37 AM
Behind the Sun
Are you the first owner?
Hopefully wasn't in an accident.
Do you let your kids significant other drive? Pothole??
Old 12-30-2020, 01:27 PM
Send a message via AIM to fintstone
Have the alignment folks look at your at your lower control arm bushings.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 12-30-2020, 03:25 PM
