Uneven front tire ware 2010 cayenne s
My tires are less than a year old. The inner 1/3 portion of both front tires are worm to the indicator. What parts need to be replaced to correct this. I have 135 k miles on the car
Thanks |
hard to say - might just need an alignment - did you get one when tires were new? - was it done correctly? - try a different alignment place - they will probably be able to tell you if and what parts are worn - i burned a set of new tires off in 6 months because of a faulty alignment
84 928 S - SOLD 2012 Cayenne S |
[QUOTE=honerboys;11159015]hard to say - might just need an alignment - did you get one when tires were new? - was it done correctly? - try a different alignment place - they will probably be able to tell you if and what parts are worn - i burned a set of new tires off in 6 months because of a faulty alignment[/QUOTE
Will start w alignment thanks |
Behind the Sun
Are you the first owner?
Hopefully wasn't in an accident. Do you let your kids significant other drive? Pothole?? |
Have the alignment folks look at your at your lower control arm bushings.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Thread Tools | |
Rate This Thread | |
