Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
1985 Porsche 928s
Tow hitch / controller wiring
Hi All,
Just getting to know my new-to-me 2008 Cayenne base. Previous owner installed a tow hitch and manual says "your Porsche is equipped with a 7-pin connector....." which doesn't appear to be the case.
What wiring, if any, is already in place for connecting a 7-pin plug and brake controller?
Any other advice on what to do and how to do it would be appreciated.
Thanks folks.
Old 02-10-2021, 10:22 AM
You have to look carefully. The stock plug is very well hidden.
If it's there, adding an electric brake controller is plug & play.
Old 02-12-2021, 02:56 PM
1985 Porsche 928s
Hey thanks! I'll get under there and have another look.
Old 02-16-2021, 07:56 AM
1985 Porsche 928s
No 7-pin
Took another closer look and nothing evident. I didn't want to splice into existing wiring but might not have a choice.
Old 02-17-2021, 08:15 AM
ILXLR8's Avatar
I have owned 04, 08 & 14 Cayenne's. In my opinion, Porsche is pretty messed up when it comes to your issue. The manuals say that a 7 pin connector is included, but in fact it is a 7 pin plug that is tucked behind a cover plate located just left of the center of the hitch. You have to add the actual receptacle. Search Pelican for Part # PNA-955-118-93-B-OEM. This information is for the factory trailer hitch only!
If the previous owner installed an aftermarket hitch, the wires are in the vehicle, but you will need a towing computer, hitch harness, 7 pin receptacle and possibly have the dealer program the car. The towing computer works to adjust shifting, interconnect alarm for trailers, connect trailer lights and brakes and maybe some other benefits. You can add a brake control by locating the 4 pin harness under the steering colume. The other option may be to tap into light wires, like the good old days. However, I am not sure of what issues you may encounter.
Old 02-21-2021, 01:33 PM
My other ride is a C-130J
RNajarian's Avatar
Here is my write up how I installed an aftermarket tow hitch with the Factory Tow Module. It may be helpful.
Factory Tow Module/Curt Trailer Hitch Installed for $440
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 02-22-2021, 07:34 AM
Tags
7-pin , hitch , tow , wiring
