Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
mhariush's Avatar
2008 957 V6 3.6 Temp Gauge not working. Thermostat replacement?
I have a 2008 V6 that is throwing a check engine code P2181 which appears to mean the thermostat is stuck open.
The temp gauge does not work. So I changed the temp sensor at the back of the block, and it worked for a brief moment. discovered that there is another sensor near the radiator, changed that one too, and it was working for day or two before stopping.
I can't find any diy repair guides for the thermostat replacement on this V6, and apparently, the factory specifies dropping engine and transmission, which I can't do at home.
Has anyone changed their thermostat on a 957 3.6L V6? Did you do it at a shop and what would this run usually? Or were you able to access it without dropping everything?
Any other things I should try before going to the dealer to have it inspected?
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 05-10-2024, 09:00 AM
