Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
Not a happy key
I have a small problem with my 2010 Cayenne. It's the key to the old beast and the body of the key has started to split. Without getting too enthusiastic I cannot see how the key body comes apart so I can rectify any faults and seal it up again. If any good folks could steer me in the right direction for disassembly I would be most grateful.
Old 06-03-2015, 10:29 AM
Mike80911's Avatar
If you are referring to the key fob they are 2 parts and are glued together from the factory. If you pry the back off very carefully you might be able to get it apart without breaking it. There are fobs available on ebay for around $10 they are not Porsche parts but they work great.
89 930 Cab Black
11 Cayenne
Old 06-03-2015, 07:13 PM
Information Junky
island911's Avatar
they are not Porsche parts and I have found that they do not work great.
The one I got was off enough from the original that no OE parts are interchangeable, with the exception of the PCBA. I wanted to use one of those for just the plastic case, but the metal key portion could not be swapped w/o interference in multiple places. And, the button portion (the flexible plastic insert) pops out (again, poor precision).
Old 06-10-2015, 10:02 AM
Information Junky
island911's Avatar
for what it's worth, the aftermarket 955 housing...
note also, no side "panic button"
Old 06-10-2015, 10:06 AM
My other ride is a C-130J
RNajarian's Avatar
Old thread... same problem. I picked up a clean key fob for my 2005 Cayenne. Over the years you can see the wear.
According to Island the only way to swap them is break the factory glued pieces. . . I’m worried I’ll end up destroying the functional yet worn original key in the process.
Any insight?
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 05-31-2020, 08:38 AM
