Go Back   Pelican Parts Forums > Porsche Forums > Porsche Cayenne & Macan Forum
rufrob's Avatar
Vibration and shutter
Hello. I'm helping a friend just bought 2005 Base model Rhd v6 Cayenne.
It starts shuttering at 60kph especially when deceleration. Check engine light came on and the dealer cleared O2 and MAS sensor. Still same problem. No light now.
I visually inspected the prop shaft hanger bearing. It looks very clean and doesn't appear loose.
Any ideas?
Never give up
Old 02-24-2017, 03:57 PM
How is it on start-up? Does it idle rough or is there any misfire codes? It may be your ignition coils, one or more may have slight crack in it. I also had another weird thing on my Cayenne S (4.5L), two of my spark plugs were slightly loose and it caused some shuttering and rough idle. I just re-fastened them to proper torque and problem went away.
Its easier asking dumb questions than fixing dumb mistakes
1974 Porsche 911 Coupe, RSR Project
1976 Porsche 911 Targa, Black
1986 Porsche 911 Carrera, Black
2006 Porsche Cayenne S, Black
Old 02-25-2017, 09:14 AM
rufrob's Avatar
Thanks for the advice. I'll check that.
Never give up
Old 02-25-2017, 02:33 PM
rufrob's Avatar
I drove it today. It's the transmission banging and clanging up and downshifting. Seems to be a known problem. Check engine light came on while driving. The prop shaft bearing is good. I wonder if changing the atf will help...
Never give up
Old 02-27-2017, 02:07 AM
Torque converter? I'm planning my fluid change now, how many mikes do you have?
Old 02-27-2017, 05:12 AM
rufrob's Avatar
114000km.
Never give up
Old 02-27-2017, 11:38 AM
