-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   86 carrera LS1 swap (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/1052886-86-carrera-ls1-swap.html)
911tracker85 04-08-2020 09:34 AM
interesting intake....
as I have been researching LS conversions I see similar things, reverse the intake.
is it even possible to not reverse the intake? from pics I can see how a stock deck lid would be in the way. but I have an extended DP deck lid, and suspect it may have room to leave the intake facing the rear....
thoughts? pics?
http://forums.pelicanparts.com/uploa...1586363470.jpg
VacantSky 04-09-2020 06:56 AM
thoughts? pics?
It won’t work, it puts the throttle body into the rear crossmember that the lid latches into, and even if you modified that (I don’t know how you would) it leaves zero room for an intake and filter. It’s not hard at all to flip it around, you have to shave a rib on the intake manifold to clear the oil pressure sensor enough to put the connector on it. Aside from that it’s as simple as remove and reinstall and reroute some PCV hoses
Very nice car though, I love a slant nose!
VacantSky 04-09-2020 07:22 AM
Originally Posted by rahtidone (Post 10814949)
The Pandemic has allowed me time to clear out my garage and evaluate my many projects (e30 turbo, Heally Sprite etc). I feel inspired to move forward on my 911 conversion that has been sitting for 14 years due starting a business, having kids etc. My son is now big enough to assist me so I am getting that itch again. Back then, I bought an 6.0L Ls1 crate motor on craigslist for $500 from a gentlemen clearing out his warehouse. I am in the process of making sure it has not seized up. I like the fact that you are taking your time, picking and choosing your purchases (not buying the full kits from Renegade or Toy Jet), and fabricating your own pieces when necessary. I myself don't have funds to just spend, especially with two kids getting close to going to college. Would be great to be able to discuss with you your process, ex I did not know that you could get only the cradle from Renegade without having to buy the whole kit, and I especially want to understand your radiator setup because i do not want to cut up the front of the car/gas tank. Looking forward to discussing your project.
Yeah if you message renegade and ask for just the cradle they’ll sell it individually, they can sell it raw without finish too to save a little extra. It still wasn’t “cheap” but it allowed me to explore all the parts by myself which is something I personally preferred, and that in turn allows you to chip away at it slowly rather than drop large sums of money at once. My car was driver (and driving) condition before I started this conversion so the sale of the 3.2 & 915 have funded everything so far. That includes a few things that had nothing to do with the conversion..!
That 6.0 you have there is likely an LQ9, it appears to be an iron block. Which will add a little weight to the rear of the car VS the aluminum block LS engines. From what I’ve read the aluminum block LS dressed for the 911 is ~30lbs lighter than the 3.2. And the iron block LS is typically 80lbs heavier than the aluminum block
I will be cutting the front of the car, but nothing past an exaggerated RSR oil cooler duct. Hopefully will be making some cuts during some quarantine time next week! Either that or refinishing the Fikse FM10’s I picked up..
911tracker85 04-10-2020 05:54 AM
thanks for the info. I see some people cut a hole in the firewall and extend the air cleaner to the inside of the car. so I wondered is you can do something in the back...
move along ... nothing more to see here ... move along...
VacantSky 04-11-2020 07:14 AM
Haha! No problem! You definitely don’t have to cut into cabin of the car to make it work at all!
911tracker85 04-11-2020 10:27 AM
yea there is the RH U and now have seen the cobra neck you found.
but got back to thinking about the intake to the rear of the car......:eek:
realized if I open up the back of the tail, it will be sucking hot exhaust air. so now toying with idea of creating a space on the back of the tail keeping the intake inside...
but sometimes the fantasy hits the reality...
pdlightning 04-12-2020 10:08 AM
Vacantsky, I want to thank you and everyone else with the info and photos.
VacantSky 04-22-2020 02:54 PM
Not much going on recently, but I did get this rennline phone mount in the mail. But instead of using it for a phone I’ll be using it for the Terminator X handheld to monitor the engine on the fly. It’s very sturdy, So I would recommend it for a phone too!
http://forums.pelicanparts.com/uploa...1587592242.jpg
VacantSky 05-23-2020 03:11 PM
Not much for updates that aren’t LS specific. Just been slowly putting my fuse box in, and really procrastinating on cutting the tub for the radiator.. I need to just get it over with. I can smell the finish line and I’m slowing down for some odd reason.. anyways!
I originally opted to use the renegade throttle cable kit just because I wasn’t too sure how I would connect a cable to the rod or bell crank and I was being a bit lazy.. turns out they out source it to another shop for fabrication and that shop is closed until COVID blows over. I waited for a few weeks and got impatient. I ended up getting a good idea of fixing something to the bell crank while I changed the bushings and decided to take a look at LS throttle cables. I settled on a Lokar 60” cut to fit cable, and a piece of scrap bar stock I had sitting in the garage gave it’s life to become the bracket by the bell crank. If anyone can think for any reason it’s not a good idea have my bracket mounted where it is, please let me know. But I think it should be okay. The nuts are torqued to spec, pics:
http://forums.pelicanparts.com/uploa...1590271653.jpg
I need to tweak the angle ever so slightly so the crank pulls the cable out straight but it should work perfectly! $80 for a quality cable and a piece of bar stock vs $169
911tracker85 05-24-2020 05:54 AM
thanks. I would prefer to use a cable for the throttle rather than drive-by-wire. guess I am just too old school.
dont like the DBY in my F150 or my wifes Audi. when you first dip into the throttle frequently it hesitates just a bit.
VacantSky 06-12-2020 07:08 PM
Curious if anyone can point me towards a clutch cable? I’m using a 930 trans in what is originally a 915 car, and my 915 clutch cable is too short. Seems there are several different part numbers for cables on the 930’s from my researching. Any help would be appreciated
Yan2947 06-12-2020 07:15 PM
I have a shortened 930 but haven't gotten to installing it yet and would have thought that the clutch cable was the same. Let me know what you find out.
VacantSky 06-13-2020 05:13 AM
Mine is shortened also, and I thought the same. I may just have to order a couple cables and use whichever one fits best. If you have a 930 trans carrier it’s not going to work as is either. I temporarily modified my 915 carrier until I can get a proper modification for the 930 carrier I picked up. The 930 carrier bolts into a different area on the torsion tube v the 915, it’s a little further EDIT: forward (not rearward, picture in follow up comment). Roughly an inch but I can’t remember exactly. Definitely no room to move the engine that far back. I saved this picture from a thread about a carrera getting a 930 drive train and this was how the 930 carrier needed to be modified
http://forums.pelicanparts.com/uploa...1592050331.jpg
The thread is titled “Frederick the great” I believe
911tracker85 06-13-2020 06:56 AM
are you using a rengade cradle? from talking to them you need to let them know what gearbox you use as the LS engine and the gearbox bolt to the cradle to get the correct fit.
but I have a LONG way to go....
VacantSky 06-13-2020 08:20 AM
I am using the renegade cradle, but it doesn’t bolt to the transmission. Only the engine and the trans bellhousing adaptor plate that bolts to the engine.
Here are the torsion tubes of a 930 and a 911.
http://forums.pelicanparts.com/uploa...1592061225.jpg
You can see that the 930 mount points sit a little further forward than the Carrera. Meaning that when you use the 930 carrier on the 930 trans in a Carrera the holes won’t line up. I had to cut and modify my 915 carrier to fit the nose cone of the 930 trans and drill two holes in it so I could hang the engine and transmission seen here:
http://forums.pelicanparts.com/uploa...1592061499.jpg
You can see here how tight the clutch cable is against the throttle bell crank, even with it tight like this it doesn’t reach the clutch arm
911tracker85 06-14-2020 06:58 AM
hmmmm.....
I specifically asked them about this as I have an SC tub and using a short BH 930 gearbox. I have the gearbox support from the 915. will be watching this thread for ideas.
VacantSky 06-14-2020 10:17 AM
Originally Posted by 911tracker85 (Post 10904814)
hmmmm.....
Not my picture, but you can see here that the renegade cradle has nothing to do with mounting the transmission to the chassis
http://forums.pelicanparts.com/uploa...1592154881.jpg
It bolts to the stock LS engine mount holes, and ties to the adaptor plate. My 915 carrier is modified just so I can hang the drivetrain and get the car running but when it’s fab time for the exhaust I’ll have the 930 carrier modified like the picture I borrowed and shared earlier
MrRPJ 06-14-2020 11:09 PM
Those are some massive spacers
911tracker85 06-15-2020 05:58 AM
interesting...
I had the impression the RH cradle bolted to the gearbox mounts in the front.
so where does it bolt?
VacantSky 06-15-2020 07:31 AM
Originally Posted by 911tracker85 (Post 10906069)
interesting...
You may have read over it, but I mentioned it bolts to the stock engine mount locations on the LS, and the adaptor plate for the trans (again, not my pic but a good side profile of it)
http://forums.pelicanparts.com/uploa...1592231458.jpg
