Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
PhilStubbs's Avatar
Send a message via AIM to PhilStubbs
where can i find swap info
i have a 71 superbeetle that i am considering doing some sort of porsche engine swap to. i have looked around on "yahoo" and couldnt find anything except this site(which seems pretty good). where can i find info on what will fit w/o cutting or welding and where i can find the engine and transmission for my swap. any help is greatly appreciated.
Old 05-06-2003, 08:51 PM
ViolentBlue's Avatar
Send a message via ICQ to ViolentBlue
Your best bet is the type 4 motor, same as in the 914. a stock 2.0L will be a big upgrade from your stock 1600 or you can go much bigger.
I have a 1.7L 914 engine in my beetle and it fits nicely, and I have it coupled to a 901 5 speed from a porsche 911
a few pics of my project
Old 05-08-2003, 05:20 PM
PhilStubbs's Avatar
how about the mounting surfaces for the engine and tranny. will porsche and vw interchange? will all porsche interchange within a reasonable time period(model year). does the tranny just bolt up to the frame?
Old 05-08-2003, 05:57 PM
you can mate a 914 engine up to your VW tranny fairly easily.
you need a vw bos flywheel 200-210mm have the beetle pilot bearing pressed into the flywheel
then you can use a beetle pressureplate and clutch disc
everything just bolts up.
Old 05-08-2003, 08:42 PM
a good place to start with swap info is Shop talk forums
Old 05-10-2003, 09:20 AM
