Sweet. This build makes me wanna move forward with my plans to slip an LS1 into my VW Rabbit.
wj |
Call me cranky, but this is a technical forum, and all the one or two line post-padding is clogging up a good thread. "Awesome", or "subscribed", doesn't add anything to the discussion. I'm all for being witty or positive and encouraging, but it's getting kind of silly around here.
Back on topic. Are you getting the modified gauges through Scott? |
Sounds like a LOT of work to change a 4 cyl front-engine FWD car into a V8 mid-engine RWD car. But it would be way cool! |
Nice build, it will be interesting to see the finished product! |
If I could do it over I would have purchased an LS6 intake. Equal gains in HP to the Typhoon and would probably fit 10X better http://forums.pelicanparts.com/uploa...1236563220.jpg |
Good new is I may need to return to Florida in April so maybe I can get the project finished up then. |
http://forums.pelicanparts.com/uploa...1236564046.jpg |
cool project
Couple of thoughts have been running thru my mind about how to do the coolant lines to the radiator. Although I think the current setup will work the idea of the trunk lid opening and closing over time will develop a weak line and it is possible that it will leak.
Has anyone ever used or worked with -16AN or -20AN Fiber braided lines? I am curious to know how flexible they are? I see several of these NASCAR braided lines being sold on Fleabay for pretty cheap and was thinking they may out last my current idea. Plus I could have the fittings welded to the radiator and not have to use hose clamps :) Second thought was if these lines could be used would -16AN be able to flow enough coolant thru the radiator effectively? I imagine -20AN lines would be no problem but are probably less flexible. Anyway, interested to hear some feedback on this idea. Here are some pics and link http://forums.pelicanparts.com/uploa...1236687470.jpg http://forums.pelicanparts.com/uploa...1236687488.jpg |
Very intrigueing project. I am most intrigued by the extra hood shock could you give details on this, mounting location, part number for shock used, ETC. Contact speedo about the braided hose he used it for his oil system.
This looks to be a well thought out build, but I have a real concern over that radiator set up. Specifically, won't having the radiator on it's side induce a substantial amount of air into the system unless you can come up with some means of removing all the air out of the radiator? Seems like you will have to have a high point in the system with a bleed valve to prevent this.
is there such a thing as a dry sump sb chevy?
yes dry sumps have been around on the sbc for years...but as someone who has had a converted car for years..alot ot these ideas are just things in the way. my oil cooler is mounted in the passengenger backseat area suitably enclosed and vented to the underside of the car and is fed cooling air through two three inch naca ducts in the quarter panel popout window. my radiator is in the front. rubber hoses and a mezziere remote electric water pump are easy to install as well as the front mounted radiator. helps a bit with weight distribution, especially when running an all aluminum engine. i still think that a 930 gearbox is the way to go especially if you want 500 horsepower and then be able to use it...otherwise you end up with power but a bit timid about turning it on! my 71 rs lookalike has an all aluminum 434 sbc with mass flo efi and dynoed at almost 600 chp. the renegade hybrids radiator set up does work well. cannot imagine opening the engine compartment and sticking my head in underneath a 210 to 240 degree radiator!
This setup might require cutting out a bit of the crossmember or using the smaller TB. The engine is going to want to move around a little bit, unless its on solid mounts.
This is a cool project! What is the weight delta between the v-8 and a 3.6 or 930 motor? Doug |
rh makes a 90 degree for this situation. not sure of flow potential especially with high horsepower.
Nice!---just a thought,---you might consider crossing the radiator hoses over,L-to R at the rad. You may have to use angle fittings ,out of the radiator but the extra hose length and the ,"across the bay",flow
may be less stressful on the hose bending? altho the hose might not like that much axial movement but the swivel fittings would take care of that---Make sense? Apologies for the Art work! http://hl.onlinestuffs.com/uploads/o...h/cd/ae/rw.jpg |
subscribed-
| All times are GMT -8. The time now is 07:22 AM. |
