Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
help 914 motor and flywheel in a 73 baja bug
hey guys i need help what is the skinny on the flywheel from a porsche 914 I'm told i need a bus type4 flywheel but i cant find one is there any way to mod the 914 flywheel to do the job any help would be great thanks to anybody who chimes in jim
Old 04-25-2009, 09:39 AM
I don't know the differences between the914 flywheel and the type IV flywheel
you will owever need a spigot bearing adaptor when using type IV engines in bugs
I think stateside tuning sell them
they'd also be able to advise on the differences in flywheels if you have no luck anyplace else
Old 05-11-2009, 10:20 AM
1303RS's Avatar
I got my type 4 flywheel/clutch kit from Kennedy. Its a type 4 center with a type 1 gear ring.
Old 02-17-2010, 08:31 PM
Hello and welcome!
The 914 f/w does not work (different offset) also needs the self support starter to work with.Where are you ? US ?
Kennedy Engineered Products (adapters/flywheel must see) if order tell it will be to a bug
Shoptalkforums.com • Index page (vw aircooled forum + ads too)
WWW.GermanLook.net (same as above forum but more specific to german look)
TheSamba.com :: Volkswagen Classifieds, photos, shows, forums, and information (really unlimited vw related ads from all over the country)
Avoid the 210mm bus flywheels is a pita go for the 215mm also Home - GoWesty Camper Products - parts supplier for VW Vanagon, Eurovan, and Bus have them.
Good luck
Old 02-22-2010, 02:15 PM
