Order Online or Call:
888-280-7799
McAfee SECURE sites help keep you safe from identity theft, credit card fraud, spyware, spam, viruses and online scams
Porsche | BMW | Mercedes | Audi | Volkswagen | Saab | Volvo | Mini
  Search Pelican Parts:
View Cart | Project List | Order Status |  Help
BoxsterGT's Avatar
Porsche Crest What axles/flanges to use w 915 in Vanagon?
Since this has been done by others in the past, can someone advise me on what axles/flanges to use with my 915 trans going in a Vanagon?
Any help would be greatly appreciated.
Thank you.
Len at Autosportengineering dot com
Old 01-12-2011, 10:05 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #1 (permalink)
BoxsterGT's Avatar
Bump
Old 01-14-2011, 05:03 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #2 (permalink)
jadewombat's Avatar
Length of axles or size of the CVs? Or are you talking year of Porsche? If you need custom ones, lowbugget helped me out when I did an IRS swap on my bus, spline pattern was the same for me on the axles but I don't know about Porsche/Vanagon stuff. I seem to remember the measurement is cup to cup minus 1/2". Best to work the trailing arm with a jack up and down through the suspension travel range and get a measurement at the tightest point as well.
Shoptalkforums.com • View topic - Bus into bus trans swap...searched, found little
'66 11-window VW Bus (Fuel-injecter'd Super-1600, IRS, disk brakes, MB CLK rims)
Louisiana Euro Car Club---www.fleurobahn.com
Old 01-17-2011, 09:48 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #3 (permalink)
BoxsterGT's Avatar
Need any info available on CVs and axles & lengths.
I was told that Jake Raby has a 915 in his transporter, so I emailed him, but no info yet.
I was hoping there is a bolt-on combination out there. I am watching "the Samba" board as well.
Len
Old 01-18-2011, 12:15 PM
  Recommend this thread for the PelicanWiki    Reply With Quote #4 (permalink)
BoxsterGT's Avatar
So far, I have learned that .......
Both the VW type 2 and the 915 use 6 bolt x 100mm CV's with a 33 spline ID.
Axle length is 22in for the Synchro, dont know if its the same for a 2wd Vanagon. This is a special length when fitted with a 915, so the axles must be made to order.
Hope someone else can confirm or refute this info.
Len
Old 01-19-2011, 04:08 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #5 (permalink)
jadewombat's Avatar
If you do get custom axles you'll probably want the aftermarket Sway-A-way (SAW) type axles though as the CV is allowed to float towards the center of the axle a lot easier than the stock type with the built in stop and ring collar, doesn't bind nearly as much.
Old 01-19-2011, 09:58 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #6 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
BoxsterGT's Avatar
Porsche Crest
Thank you JadeW-
I called SwayAWay and have learned that they keep 22in long 33spline axles in stock (common for off road use) and also learned that early 944 CVs are 100mm dia 6 bolt w 33spline hubs.
I have a few used 944 axles around the shop so I will cut & weld one into a 22in length to test fit to the Doka.
If it fits I will S/O the new axles from SwayAWay.
Cheers,
Len
Old 01-28-2011, 09:48 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #7 (permalink)
The Syncro, dont know if its the same for a 2wd Vanagon.
Old 01-12-2012, 05:59 AM
  Recommend this thread for the PelicanWiki    Reply With Quote #8 (permalink)
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
Copyright 2011 Pelican Parts - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
