Boxer Family
Doug '86 911 PART OF MY SOUL: '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster (#2), '72 911T, '88 911, '99 Boxster (#1), '84 911 Turbo Look, '73 911 Targa, '88 944 |
I vaguely recall the grand national turbo 3.8 v6 being a swap option. IIRC, in stock form that motor put out 275hp...
renegadehybrids.com has kits for LS and small blk conversions and subie conversions. Im currently work for Ls conversion, I have not ruled our V6 yet just have not found motor yet that meets my criteria. i have a wrx it kicks ass but I want my 911 to be faster than wrx. right now subie kicks its butt.
Fords new 3.7L would be awesome. All aluminum, 7K RPM from factory, 300 HP, and 31 MPG in my son's mustang. They are fast and sound great. I have the same motor in my truck, great motor - smooth, quick, quite. Would need a good electrical person to do the swap.
Or an 3.5 L twin turbo ecoboost - 365HP 425ft lbs torque. |
Straight shooter
Vr6 turbo... cheap, reliable, easy to work on... powerful.
Andrew 74 911 |
Both of those ar heavier, taller and more exepnsive to acquire and modify than an LS. And the conversion cost would be the same. LS still wins.
http://forums.pelicanparts.com/paint-bodywork-discussion-forum/502929-diy-iroc-rsr-conversion.html http://forums.pelicanparts.com/porsche-911-technical-forum/649179-rsr-ls-conversion.html |
I can't say that the LSx doesnt win, but the 3.7 Ford and 3.6 Chevy engines are great and LIGHT. I think the 3.6 is listed at 375lbs with 300hp. Easier packaging in rear in regards to space/weight. Don't believe any of the FI engines are struggling with height. Have been researching these exact engines for an MGBGT swap. Thought the snappy lower torque nature might fit the character of it better than a torque monster. If your building a small tired car, you don't need a LSx engine.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody extreme DD (no targas or cab's allowed )67 XKE,67,68,69,70&94 Mustangs, GS, MGB http://www.hubgarage.com/mygarage/LukeSportsman |
Straight shooter
Ls engine is a great engine but if you're into keepin Germans speaking German then the VR6 with a turbo is the way to go. The generic American v6 engines are okay but you're a smidge away from driving a grand caravan or grand am.
Andrew 74 911 |
While looking for the weight of the Duratec V6 I just read the V12 version of that technology (Duratec) is the basis for the Austin Martin line.. Not too shabby.
The B may be different, but you're going to have a height problem with anything overhead valve in the P car. It's easy enough to get around that with a different choice of decklid and wing but the main thing is I wouldn't waste the money.
Essentially, since the bulk of the cost is in the conversion and not the engine, you're shorting yourself 100-150 horsepower. And "snappier nature of the torque" is just silly. LS engines can easily make twice as much torque as a VR6 or any of those other v6's. And it's torque that moves you. The other thing people don't realize is that there is a huge difference between peak horsepower/peak torque and what I'll call area under the curve. A VR6 engine, in particular, is a great little motor. It spins great, sounds great and it's a smallish package. But go look at the horsepower and torque curves. An LS engine makes more horsepower and torque everywhere - from idle through redline. When you sum up all that horsepower, it's a LOT more powerful than the VW. And, you can feel that power everywhere - there's an immediacy these v8 cars have that you'll lose. It'll feel more laggy and lazier, like the flat 6 you took out of it. And the LS engine weighs about 350lbs, too. I'm telling you, you guys don't realize how tiny the LS package is. Here's a picture. ![]() And, that LS engine has a deep sump oilpan on it. The one most people choose is 3" shorter. Hal
Straight shooter
No offense but it is painfully clear you've never owned, driven or researched VR6 turbos. This mindset is exactly the type of driver I enjoy roasting in their "muscle" car out of the toll booths as they're completely clueless and unsuspecting.Stock vr6 with turbo handles ~600hp. Add pistons and rods and you're about 1000hp capable.
The LS is a great engine but not the easiest to work on and not the cheapest to modify for power. Right out of the box in stock trim it is superior to the VR6 when also in stock trim. BUT, cap your spending on engine and performance adders (non-refillables) at $6g and you have a 600hp vr6 and a mostly stock 400hp LS if you find a decent specimen that isn't beat to death already.
Andrew 74 911 |
Straight shooter
...And if you want a Porsche VR6 they exist in the Cayenne.
Some education... love the street golf driving around the Camaro popping the wheelie out of the hole. That golf is stock block, big cams with the turbo. https://www.youtube.com/watch?v=sFj9d6N8bfg
Andrew 74 911 Last edited by Lapkritis; 01-28-2013 at 06:47 AM.. |
There are all kinds of neat ideas for awesome engine conversions. Proven is always good and the LSx has been a proven conversion with parts readily available. If that does not float your boat, for the same hp as a 3.6 engine, the Suby has some great flat 6 engines that Porsche did the consulting for. The ez30r 3.0 liter 250hp. or the ez36d for closer to 260 with improved torque. Both the Suby flat 6 engines weigh 100-150lbs less than the 964 3.6 or the LSx engine.
If I had a 911 roller and could not afford to put a good Porsche flat 6 engine, I would go with the Suby for sure.
Ernest Johansmeier ernestj911@gmail.com |
I have always wanted to do a rotary engine in a 911.
Captain Annoying
If people were desperate to fit a V6 into a Porsche, I'd go with the Mazda KLZ (and turbos), or the Honda or Suzuki engines (alloy, relatively light and good power) or the Mitsubishi 3.8L V6. Audi make a great V6 but they are expensive to maintain and aftermarket is minimal. However, I'd never do it to a 911. Why would you? LS1 ticks all the boxes and then some, and would be cheaper to convert on account of the vast amount of aftermarket support. Having said that, the perfect candidate for a V6 conversion would have to be the early boxster. LS1 doesn't fit, and Subaru engines sound like arse.
this time for sure... |
