-   Porsche Engine Conversion Tech Forum (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/)
-   -   RSR LS Conversion (http://forums.pelicanparts.com/porsche-engine-conversion-tech-forum/649179-rsr-ls-conversion.html)
not_hans_stuck 08-02-2015 01:41 PM
More work accomplished this morning. I pulled the ECU, blew out all the connections, painted it black, painted the mount black. Made a bracket to mount the engine fuse harness and obd2 port to. Bolted all that stuff in. Reseated the harness in the computer and fired it up again.
This time, it was hitting on all cylinders. Sounds great.
Here's the video.
https://youtu.be/Lnx1zlLlOJs
Here's a couple of shots of the computer mounted and the bracket.
I still have a lot of routing and straightening to do, but it's getting closer.
http://forums.pelicanparts.com/uploa...1438547968.jpg
http://forums.pelicanparts.com/uploa...1438547986.jpg
911JeffS 08-04-2015 05:54 AM
ata boy Hal
Congratulations Hal very nice ;) I'm sure there's more tweaking to do but you did a fantastic job all the way through. I personally have been reading and following taking notes and images. Thanks for sharing so much Hal. I do need to update my thread but it is on four wheels again suspension brakes and most welding completed. Need to keep pushing though. Jeff
not_hans_stuck 08-05-2015 06:16 PM
Jeff,
That's excellent news. Congratulations. And, yes, post pictures!
Hal
not_hans_stuck 08-05-2015 06:47 PM
Been working on it a little in the evenings.
I had a non-motor project. The sunroof gearbox wouldn't close it all the way. This led me to leave the sunroof headliner off it so I could press it up into place. I replaced the gearbox and installed the headliner.
http://forums.pelicanparts.com/uploa...1438824096.jpg
I cleaned up the wiring as much as possible. My plan was to make all the cables run up either side of the center console, and from under the seat down the outer rail where the factory engine harness ran. I did ok, but couldn't get them all.
The connection from the computer to the OBD2 port is too short to do anything with and the pedal controller is very difficult to place. It just has to go on the floor. Nothing you can do with it. All in all, I'm not very satisfied with the wiring harness. It was lengthened and cleaned up, but not nearly enough - on either count.
I would have made the alternator connections longer, the pedal connection longer, the O2 sensor connections longer and then there's a line that goes to the knock sensor and the starter - those two are right next to each other on a vette, but they're on opposite sides in this configuration. I lengthened them all myself, but it would have been nice for them to have done it. I'm also not a fan of the covering material they used. It's basically that split corrugated plastic tubing you get at Lowes wrapped in wide black non-sticky tape. It would have been better with a modern kevlar cover. I used that stuff everywhere I could. It's like Chinese handcuffs. It's a woven material that accommodates different bundle sizes well.
It would also have been nice if the harness had been made to integrate the relays for the cooling fans, fuel pump and water pump. It had signal wires but no power connection or relays.
I'm asking a lot, I know, but that's just my thoughts.
Here's the cleanup of the wiring under the seat.
http://forums.pelicanparts.com/uploa...1438824688.jpg
If you look at the bottom bolt on the parking brake you can see a little switch panel I fabbed up. This is a pair of manual override switches for the cooling fans. It's temporary for now, but I may keep it. Also, the pedal harness is laid out on the passenger floorboard because the plugs make it too large for me to shove it under the center console carpet. I'll leave that job for the upholstery man.
http://forums.pelicanparts.com/uploa...1438824820.jpg
Driver seat back in.
It's not on the road yet. I don't have brakes. I pressure bled it and didn't get a pedal. I had to dig around a little but it ended up having several leaky connections. I'll have to fix those before I can continue. I was too tired to do it this evening and I didn't have anymore brake fluid anyway.
I also ordered an A/C condenser. That'll be the next project. When the condenser gets here, I'll have everything I need except fittings and hoses. And the hose compression tool thingamabob, of course.
I'm still not happy with the electrical routing. The wires that run from the computer side to the battery side need work. Also, I have a ton of connections going to the back post on the cutoff switch. I've left those long for now because I'd like to devise some sort of power distribution block that can clean that up. I could put it under the passenger seat but I can't really find anything. I need something like 200 Amps and all the ones I see can only handle 30 Amps. Home Depot has some residential stuff that could handle it but it won't fit under the seat and wouldn't actually look better. So, dunno. I'll leave it for later.
Hal
Tremelune 08-05-2015 07:17 PM
Power distribution is easy (strip of metal with a few bolts in it). It's the fusing that can get ugly. Regular blade fuses go up to 40A, Maxi goes to 120A. What power do you need to go where?
not_hans_stuck 08-07-2015 07:42 PM
I have a bunch of circuits. Each of the circuits is fused. If the individual circuits are fused, do I need to fuse the distribution block?
And McMaster-Carr had a nice one. I'll probably do that. It just a strip of metal, like you say, but it has some posts on it and it's mounted in plastic - which can be mounted to the floor - and it has a nice clear cover.
The individual circuits are as follows.
3 from the Porsche - from the main chassis harness panel.
2 radiator fans - 30A each.
1 radiator fan manual bypass signal
2 Ignition system - one switched and one hot all the time. Multiple fuses.
1 coolant pump - 30A
1 fuel pump - 30A
So that's 10 connections. No wonder it looks so messy on that single post.
I also still have the main power feeds to the new AC unit to do.
Hal
not_hans_stuck 08-07-2015 07:47 PM
I spent some time on the brakes. There were leaks. I evidently didn't tighten all the connections. Guess I'll go through all of them tomorrow.
Good thing I already re-torqed all the other bolts on the car. It just doesn't pay to let a project car sit. Entropy and the Human Memory Model are working against you all the time.
Tremelune 08-08-2015 05:38 AM
Any time the wire gauge is reduced (so like 8 to two 10s), you should fuse the smaller wires, even if the larger wires are fused. This hideous website is solid gold (check out section 14 on the right):
Basic Car Audio Electronics
I buy most of my stuff from Waytek (they have a few nifty fuse junctions):
http://www.waytekwire.com/
I gotta swing by McMaster-Carr if I'm ever driving through Jersey...I didn't know it existed.
not_hans_stuck 08-08-2015 06:27 PM
Excellent site! Thanks!
My small wires are all on separate fuses so I'm good to go.
Hal
not_hans_stuck 08-08-2015 06:29 PM
So this was it. This was the day. Wait for it...
First thing I did was bleed the brakes again. It had a small leak at the 90 fitting that goes into the tunnel from the front. I tightened that up and it held pressure perfectly.
We put the decklid and hood on. Installed the passenger seat and the tires, then....
Drove it! Yup. Big day.
Here's the videographic evidence that said event actually took place.
https://youtu.be/9BzwZjQp4JY
And here's a flyby.
https://www.youtube.com/watch?v=e9HxzYspRPo
You'll note that it sounds much more like a Porsche than a Chevy.
Hal
not_hans_stuck 08-08-2015 06:39 PM
We didn't stop there.
The next thing we did was work on the AC. I have all the parts on order for delivery next week so I couldn't install it but there were details to work out.
The factory AC controls look like this.
http://forums.pelicanparts.com/uploa...1439083999.jpg
The OldAir AC control panel looks like this.
http://forums.pelicanparts.com/uploa...1439084033.jpg
Well, obviously, that wasn't going to work.
So I bent up some sheet aluminum and did this.
http://forums.pelicanparts.com/uploa...1439084088.jpg
And after paint, it looked like this.
http://forums.pelicanparts.com/uploa...1439084325.jpg
That's much better!
not_hans_stuck 08-08-2015 06:56 PM
And, why stop there?
After all that, there was another issue to be sorted.
I don't know why, but for some reason my rear swaybar won't fit. The crossmember interferes with it. This is documented earlier in the build. I decided to defer that project and the deferment is due. I installed some long bolts and let the mounts hang, then threaded the swaybar through and tightened them up until there was minimal clearance with no interference. This yielded a .625 inch gap.
A friend of mine just acquired a Grizzly mill and this seemed like an excellent first project for it. I already had a 1.5"x1.5"x5' bar of 6160 Al stock.
So, we set off.
Here's the process and results in images.
http://forums.pelicanparts.com/uploa...1439085292.jpg
http://forums.pelicanparts.com/uploa...1439085317.jpg
http://forums.pelicanparts.com/uploa...1439085356.jpg
I'll install it tomorrow and post a picture. Next weekend is the AC installation hopefully.
kylejohnston1 09-04-2015 05:28 AM
I just read through the entire thread and really enjoyed it! Excellent work thus far! I am in NW Houston and would really like to see your car in person when it is finished. Any progress since your last post?
dohc 09-05-2015 09:14 PM
Nice build !
DOHC :)
not_hans_stuck 09-12-2015 01:01 PM
C'mon by! I'm in Katy.
not_hans_stuck 09-12-2015 01:13 PM
OK. Tore it apart again. I'm adding the AC in. As it turns out: "I'll just add it in later" wasn't such a good idea.
And then, of course, you get the five most expensive words ever spoken: "While you're in there." (four words, I guess, with a contraction).
So, here's the list of stuff we're trying to do.
Ditch the Evans. Didn't like it. Going to water and water-wetter.
Create and install a duct from the bumper to the radiator.
Install the AC.
Install the AC includes several sub-items - because before you can do anything, you have to do something else first.
Sub-item 1: Seal up all those holes in the "firewall" including making a backing plate for the extremely cool Rennline smugglers box cover with all the holes in it.
Sub-item 2: Move the AC system box so that the hose connections will fit in front of the gas tank.
Sub-item 3: Install the switch block in the center console (done)
Sub-item 4: Run more giant lines all the way up and down the bottom side of the car.
Also, in order to swap out the coolant for water, I'll need a coolant reservoir.
Here's the progress pics. That damn vent took 3 weekends. It's finally done except for the final welding.
http://forums.pelicanparts.com/uploa...1442088728.jpg
http://forums.pelicanparts.com/uploa...1442088751.jpg
http://forums.pelicanparts.com/uploa...1442088774.jpg
http://forums.pelicanparts.com/uploa...1442088789.jpg
Mitch Leland 09-12-2015 03:44 PM
Radiator vents...
Nice work... What goes in gotta go out... Have you thought about that? I increased the airflow over my center radiator by changing the bumper to a 997 GT2 bumper which has vents on the top of the bumper. I believe I'm moving more air now across the radiator. Before the radiator was tight to the trunk bulkhead and no where for the incoming air to go. I tipped the radiator forward so the air hopefully now passes through the raditor and out the vents. I appreciate my solution won't be the same as yours since the model difference.
http://forums.pelicanparts.com/uploa...1442097641.jpg
not_hans_stuck 09-13-2015 06:03 AM
Mitch,
On these cars, the radiator is laid back. The air passes in the front, crosses the radiator then exits under the car like any other normal car.
The hole in the front pan where the gas tank used to sit is where the air comes out. The back half of that hole is taken up with the new gas can. The radiator and the shroud actually sit over the front half of that hole. The exit hole is a little larger than the entrance hole so the air pressure decreases across the radiator. This reduces the air temp.
In this car, the front bumper has the big oil cooler hole. That hole is slightly smaller than the cutouts through the slam panel and it's lower. When you looked directly into it from the front, most of what you saw was just nothing - air would flow in that hole and then go under the car.
I'm pretty sure it was creating a high pressure area right in front of the radiator, stalling the air out, roiling it under the car. When I left the fans on, it would cool normally, but without the temps would start to climb again. I expect the duct work to eliminate that problem.
Also, the ductwork was always part of the plan because it looked really bad without it. It was just on the second punch list. The one with the AC.
Even without the duct though, it never overheated - just ran hotter than I wanted it to.
Hal
Mitch Leland 09-13-2015 08:31 AM
Hal,
I should have known you had that figured out... My last trip to California I pulled into Tucson and it was 111 degrees. In traffic at those temps my engine gets very hot, but doesn't boil. I haven't figured out the difference in cooling from my Escalade (LS1) to basically the same engine in the 996 (LS3) why the cooling in the 996 doesn't perform as well. I've got over 6 gallons of coolant in my car, albeit the engine is in the rear and probably doesn't get the airflow that when it's in the front?
Maybe the mechanical water pump moves more water than the electrical water pump? However I'm guessing if you move the water too fast then the radiators won't do their job... The point is that the front mounted engine in the Escalade will idle all day in high temps without getting hot, I still can't do that in the 996 conversion. For most driving it's rock solid at 190 degrees.
Maybe some Sunday morning meet half way for brunch...
not_hans_stuck 09-14-2015 08:03 AM
I can fill you in. There's two things going on.
First. LS engines are good to 240 degrees. They run at hotter temperatures to assist with emissions and power.
Second, there's a thing called Hysteresis. This is an engineering term meaning that the response to the input is nonlinear.
How it applies in this case is with your temperature gauge. Most commercial cars do this, but I cannot confirm that the Escalade has it. I think it's a 99.9999% chance.
How it works is this. The gauge is linear from cold to say 185 degrees. Then from 185 degrees to, for instance, 240 degrees, the gauge doesn't move at all. Once the temperature goes past 240, it's linear again.
This eliminates people stopping for service because they're worried about their cars temp yet still allows the car to have a gauge instead of an idiot light.
The gauges in your porsche don't do that. They report the actual temperature. That's the difference you're seeing.
Get yourself an ultragauge or something like that and plug it into the obd2 port on the Escalade, you'll see the temps bouncing all over the place.
And, yeah. We should do that. I still have to build some confidence in the car. It's been running great but, I'm still a little nervous about it.
Hal
Tremelune 09-14-2015 08:07 AM
:eek:
Mitch Leland 09-14-2015 11:31 AM
Hal,
That's good information... I have a digtal water and oil temp gauge as well so I can track the temps on both the dash temp gauge and the digital gauge. I know people have said that the LS motor likes heat. Sometimes I think I get hotter than the car just worrying about temps.
I probably have done just about everything to reduce high water temps in high ambeients. I have 1-1/2" aluminum water piping from my manifold to the radiators, a large 3rd radiator, 190 degree thermostat, new aluminum radiators that replaced the factory radiators.
I've driven the car cross country in temps over a 100 without it boiling, probably the biggest worry is watching the oil temps in stop and go traffic over 90 degree ambients. I've never been over 250 degrees on the oil for long. I have a small oil radiator which has helped that.
Proof: last trip to California I had to stop on a border inspection on Highway 8 going into San Diego, the line was over a mile long, the ambient was 104 degrees... that's no fun. I said to myself if they would put the same effort at the border it might do more good...
Thanks again for sharing your knowldege with us...
not_hans_stuck 10-26-2015 06:12 PM
A few changes since the last post.
Created a duct to connect the mouth in the front bumper to the hole in the slam panel.
http://forums.pelicanparts.com/uploa...1445908062.jpg
It's welded aluminum attached to the same mounting holes as the inner duct work that makes the box for the radiator.
http://forums.pelicanparts.com/uploa...1445908090.jpg
These pictures only show it tac'd up, but it was seem welded.
This is it final fitted.
http://forums.pelicanparts.com/uploa...1445908118.jpg
And how it looks with the carbon wrap. I backlit it with a flashlight for effect.
http://forums.pelicanparts.com/uploa...1445908146.jpg
I also added AC. The lines aren't connected yet, but all the heavy lifting is done and the car is back on the ground and running again.
http://forums.pelicanparts.com/uploa...1445908342.jpg
Mitch Leland 10-26-2015 08:30 PM
Hal, outstanding... I love your fabrication.
baloo 10-27-2015 04:43 AM
Great work!
How in the world did you get those BowTie cutouts at the top back of the duct??
not_hans_stuck 10-27-2015 05:45 AM
Originally Posted by baloo (Post 8852699)
Great work!
I have a friend with a CNC Plasma table. We just cut it out of steel sheet and welded it in instead of the slam panel sheet. There's some pictures in the thread somewhere. It was straightforward and minimally invasive. To restore to original you just cut that sheet out and weld back in a repro panel from Restoration Design. Most people just leave a hole, but I didn't like that. The vented panel seemed more rigid and cleaner.
Plus, the bowties. :)
kylejohnston1 11-02-2015 07:25 AM
Looking good...awesome craftsmanship!
not_hans_stuck 11-15-2015 06:21 PM
Working through punch list items.
First, I extended the fuel tank sending unit harness. It's now plugged in and up.
Installed the front cross brace again.
The AC hoses are done. Still need to wire up the compressor clutch and charge it. Getting closer though.
Re-wired all the main power lines. You guys will remember that I ran everything back to the disconnect switch on the rennline battery mount behind the seat. This was only temporary. Now that the car is nearly done, I could size the bus bar.
Here it is installed.
http://forums.pelicanparts.com/uploa...1447639985.jpg
This looks a whole lot cleaner and should make the wiring a bunch safer.
There are two other wires visible in this image on the center console. One is the OBD2 dash pod. I haven't decided if it will become permanent. It may. For now, it's my only real gauge. The other is the gas pedal drive-by-wire harness. It'll get routed up the driver side. The red wire in the bottom left is my battery charger pigtail. The big wire coiled up on the floorboard is the factory Porsche seat harness. It still has the power seats.
I also had guy come by and roll the fenders. This was, you may recall, one of the "doh" moments we had. We completely forgot to roll the fenders before we finished the car. Rookie mistake. I'd been worried about it ever since, figuring it would cause all sorts of paint issues.
As it turns out, he did a fantastic job of rolling them by hand with no paint cracking, peeling or blistering. It looks really good.
Here's a pic. Not much to see but it's there.
http://forums.pelicanparts.com/uploa...1447640198.jpg
Tremelune 11-18-2015 10:42 AM
That looks great. Be sure to fuse all those power wires when their gauge decreases. Ideally, some blade fuses would be built in to the distribution block.
FUSES
Scroll down to "ANY time that the wire size is reduced, you must add a fuse in the line (at the point of distribution) to protect the smaller wire."
not_hans_stuck 11-21-2015 04:09 PM
FUSES
Thanks! I don't think I stepped down anywhere. Everything is a home-run all the way to the component or back to the factory fuse block. In fact, 5 of them are just extensions of the factory wiring harness. Gauge stayed the same.
Tremelune 11-21-2015 04:15 PM
Am I interpreting this right? It looks like a 4-gauge power wire comes in from the left under the seat, and is then distributed to a bunch of smaller-gauge wires out the top and bottom of the distribution block.
not_hans_stuck 11-23-2015 06:58 AM
If you scrutinize the external pictures of the car over time, you might notice that the tires seemed to get smaller shortly after the car was returned to the road.
That's actually true. But, as of this weekend, the original, correct, tire sizes are back on the car and thanks to the fender rolling (and maybe alignment), there's no rubbing and no interference.
It looks much better.
The correct tire sizes are - 275/40-17 F, 315/35-17 rear.
The old tire sizes were 255/40-16 F, 275/40-17 rear - I bought the small tires for the front and moved the fronts back.
The bigger tires look MUCH better. The tire sidewalls are both vertical again. Yay!
I know, you say: " that's all you did this weekend?" Yup. That was actually a huge PITA - I dropped the spring seats and moved the suspension through it's entire range of motion to check for interference. And, while I had the tires off, I scrubbed the crap out them to get them shiny and black again.
http://forums.pelicanparts.com/uploa...1448290668.jpg
not_hans_stuck 11-27-2015 06:34 PM
Put 40 miles on her today. Temps hovered around 217 degrees. 100 degree inlet air temp. Pretty pleased!
not_hans_stuck 12-03-2015 07:57 AM
OK. Here you go. We've had many, many discussions on this forum about the effects on weight of swapping your flat 6 for an LS1. Herewith presented for the first time anywhere is a before and after scale picture.
This is the data from before the flat 6 was pulled.
2566 Total
LF 481 RF 487
LR 804 RR 797
F/R Bias 37.6/62.3%
Gas on E, no Driver, Oil Full.
http://forums.pelicanparts.com/uploa...1327797338.jpg
And here's the after data - gas tank is full for this one.
2578 Total
LF 458 RF 466
LR 839 RR 815
F/R Bias 35.8/64.2%
http://forums.pelicanparts.com/uploa...1449157557.jpg
Based on a wheelbase of 89.4" the cg moved rearwards 1.5".
Also note that an RSR coilover conversion and a Boxster brake conversion was also performed on the car between the before and after weights.
There you go. The real data. Let the debate begin. My work here is done.
Tremelune 12-03-2015 08:50 AM
The LS is a phenomenal motor. Most debate revolves around purism.
I'm very interested to see how this thing shakes out over a few thousand miles and some extreme conditions. Good work on getting real numbers.
not_hans_stuck 12-14-2015 03:09 PM
Thanks. It's shaking out. Various little issues but I'm getting them sorted one by one. It's slow but steady progress.
It helps that the car is rabid fast...
Mitch Leland 12-14-2015 03:46 PM
Purist stuff...
When I did my conversion on my "03" 996 C4S I had no compunction about upgrading the power plant. First the 996 engine is suspect, When I raise the deck lid I want to see an engine, not air cleaners and hoses, and I knew the LS motor was high horse power with less complications. I've never figured out why Porsche still flogs the flat 6. The new ones are a piece of work, but complicated. Germans love complicated mechanical things. Example, years ago I had a 300SL Gullwing that I restored. The ash tray had at least 6 moving parts for one little ash tray.
The V8 fits equally well as the flat 6 and offers so many more possibilities. The 996 will probably not be a collectible car any time soon, plus the numbers they've made will not lend themselves to highly sought after car. I've had limited production cars that you wouldn't touch with a conversion.
Then there is all this back dating that goes on, what's the difference, I know it's still a Porsche, but you're walking a fine line.
You only have to drive one of these conversions to know why we did it. I have a purist die hard enthusiast friend who condemn me to Hell on Earth, after driving my car there was a slight smile that came across his face, and that said it all...
Warning, these conversions are not plug and play and will cost more than you expect, but worth every penny and months of work. Sorry for one man's opinion, you're welcome to retaliate...
dtakenname 12-31-2015 01:43 PM
Hi,
Great work!
not_hans_stuck, are you going to do any thing to gear ratios or final drive? I remember another member had to modify the transmission to lower the revs and the temperature.
What is your rpm at 60 miles/hr?
Are you over all happy with the running and idling temperatures specially at stop and go traffic?
Many thanks,
Happy New Year all
not_hans_stuck 01-04-2016 03:47 PM
It's a little short on gears. 1st gear is vestigial, really. I don't really have any issues with temperatures, though. All is good there. I really like the torque multiplication of the lower gears. Up to it's top speed, which I think is around 130 or so, it pulls like a beast! Who needs a turbo? Lol.
not_hans_stuck 04-20-2016 06:57 AM
pic from an event this weekend.
http://forums.pelicanparts.com/uploa...1461160670.jpg
