Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
Bradley
decklid clearance. they do make a plastic valve cover without that baffle that would probably clear the regular decklid. this motor sits surprisingly low in there.
Old 05-24-2013, 02:29 PM
Bradley
how it sits now. its now just a matter of putting everything back together
Old 05-24-2013, 02:31 PM
onefstm's Avatar
Send a message via AIM to onefstm Send a message via Yahoo to onefstm
Looks great. I absolutely love the wheels! What did you have to do to make them work?
Also, is there an intercooler in the decklid?
Old 05-25-2013, 01:40 PM
300hp 1800lbs is the goal
pksystems's Avatar
subbed
The '66 912 Bastardization project has begun.
Note to PO's: LAY OFF THE FREAKING BONDO!!!!
The science was settled: Earth was flat.
Galileo : Flat Earth denier.
Old 06-03-2013, 09:42 AM
Bradley
Hey buddy! The wheels were a nightmare and my lack of Porsche experience probably didn't help any. The wheels have an extra thick back pad. When i went to test fit i realized the stock studs were to short. Now if it wasn't bad enough needing to buy 60mm studs i then find out that when the rear hub is taking apart i will need new bearings. Now at the point i'm at they have flat back and could use to come out maybe another 1". I can't run a conventional spacer as the studs will stick out and hit the wheel. I could switch to a bolt on spacer but it would need to be thick enough to cover the extra long stud (to far out) OR cut down the 60mm studs which im not wanting to do. Ideally they would work best with stock studs, a 25mm bolt on spacer and they would be flush. I will most likely sell them.
No intercooler. I need to switch to the plastic 24v valve cover to remove that baffle and i could maybe get it to fit. i need to run my filter as well and that might need to go up in there as its already going to be close to down pipe. i will probably go water/meth injection when i'm ready to turn up the boost.
Old 06-03-2013, 01:11 PM
Really clean little project. I love the camo.
Old 06-08-2013, 04:20 AM
Bradley
Finally got the 10 little trim screws i needed to install the rear glass. I used the rope trick. Super easy to do. Gonna try windshield tomorrow.
Still on that wiring game.
Old 06-08-2013, 06:46 PM
Bradley
Had my buddy Stanley weld up some tips, dual 2.5" pipe and made me a smooth 2 into 1 transition. just need to cut a couple more tight 90's and exhaust is done. I'll get some oil and gas in it this weekend and see what happens.
58'' from turbo to tip. should be rowdy
Old 06-25-2013, 02:18 PM
Bradley
lots of little things to button up but shes on the ground. went to fire it up and the fuel pump was locked up. looked a bit crusty but i thought it would work. nope. new pump on the way
Old 07-19-2013, 11:44 AM
Bradley
Some of the interior has arrived. need to send off seats soon.
Old 07-19-2013, 11:48 AM
Bradley
exhaust complete
Old 07-19-2013, 11:51 AM
Bradley
Worked on the bumper while waiting for fuel pump.
cut some plastic templates
epoxied in
sanded flush
first coat of filler
Old 07-19-2013, 11:52 AM
Bradley
exhaust finished. car is running and driving.
Old 11-23-2013, 05:46 AM
jadewombat's Avatar
Purty. Need some videos...
'66 11-window VW Bus (Fuel-injecter'd Super-1600, IRS, disk brakes, MB CLK rims)
Old 11-26-2013, 06:40 AM
