Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
Question Transmission options / V8 914
My car is going to be light and have loads of HP and torque. I would really like to run an auto transmission. I get the fun of shifting and its a blast but I've been driving a auto for some time and its not bad. This car being set up with a nasty LSx engine is surely going to be a handful. I know many 911s came with autos and they carry loads of HP so surely it would hold up with such a light car. Anyone have any info regarding a auto that I might be able to use ? I also don't wish to spend 10k on a trans. They are computer controlled units and that's also a issue. I really don't think there's a hole lot going on computer wise as to not be able to at least get the car to shift. I'm a tune up and driveability tech and get all the computer control stuff well.
I think one of the big top speed events was won by a 911 a few years back using an auto trans as well.
Old 01-26-2014, 11:33 PM
I was hoping to get some input but auto transmissions are real technical and specialized.
Old 01-28-2014, 10:35 PM
Well , most 914 owners have 2 legs they can use
There is a tread about using an Audi 5000 trans on 914world, and I believe someone used a Boxster tiptronic behind a 3.2. At your power level, most people would use an inverted G50
Sent from my C5503 using Tapatalk
Old 01-28-2014, 11:15 PM
914 Geek
I don't know of anyone who has gone with an auto box for a high-powered motor. I am sure there are ones out there that could be made to work, but you would probably be blazing your own trail.
The 911 gearboxes spin the "wrong way" for use in a 914. I believe that it is non-trivial to flip their ring and pinion gear, requiring at least a fair amount of machining. You can get a similar effect by flipping the whole transmission upside down, but then you have to deal with the fluid not being where you want it to be and so on.
You may be able to make a 928 gearbox work, but it will require fabrication and work. The newer Vettes with transaxles might be made to work as well. The Boxster trans should fit reasonably, but you still have to fabricate a mount, work out where the starter goes (because it's on the engine side), and of course control it.
I've read speculation about using a Subaru gearbox, either from a FWD Scooby or from an AWD one with the transfer case locked.
.... Wait a minute, I just remembered something. There was someone who, I think, used a Toronado transmission coupled to an SBC. It was only a two- or three-speed, but it was simple and could hold up to a V8 at least reasonably well, But I don't remember seeing any photos of the setup.
It is quite unusual, though. Very few automatic transmissions have gone in 914s at all through the years.
--DD
Old 01-30-2014, 12:02 AM
I have done no research on this, but
I see guys with the sandrails running hot 500hp LS V-8's running a tranny called a Mendola (I hope I spelled it right). Might be worth checking out!
Old 03-03-2014, 01:22 PM
Custom Fitted
Subaru 2WD Conversion Kit - Bremar Automotion this is how I'd try to do it..... It might take a really built Subaru auto trans to do it maybe find an auto wrx trans and beef it up..... Good luck, and best wishes, I like the end goal, as its similar to mine....
Old 03-03-2014, 09:25 PM
jadewombat's Avatar
Mendeola. About $8,000-12,000. There's others out there similar, Fortin, Hewland, etc. but these are manual trans. though.
Shoptalkforums.com • View topic - SUPER BEETLE
Just about any year FWD auto Audi V6 or V8 can handle this type of power and abuse of an LS1.
'66 11-window VW Bus (Fuel-injecter'd Super-1600, IRS, disk brakes, MB CLK rims)
Old 03-04-2014, 05:13 PM
jadewombat's Avatar
It's manual Audi FWD, but you get the idea:
Volksforum.com - Ruud's Fridolin Project
Mated to a W12
Old 03-06-2014, 10:23 AM
jadewombat's Avatar
Another example:
VWVortex.com - No aircooled exp.+ 78 Champ. Ed. Bus= Interesting build!!!!
Old 03-13-2014, 03:30 PM
JEM JEM is offline
JEM's Avatar
a dreind put a northstar engine and ewd auto trans in a mr2 i have been thinkin this could be an option for our cars
jerry
JM Motorsports
Custom Paint & Bodywork
81 911 SC ,black
73 914 V8 LS1
83 Audi Ur-Quattro,black
Old 03-27-2014, 04:18 AM
914 Geek
The MR2 uses an engine and transmission that are mounted left-to-right, like most FWD cars have. The 914 uses a setup that is longitudinal, with the engine sitting in front of the transmission.
The transmissions usually care a whole lot about which way they are oriented in the chassis, so I think the MR2-type setup would be out.
--DD
Old 04-03-2014, 03:07 PM
JEM JEM is offline
JEM's Avatar
the way a toyota engine fits in an mr2 has nothing to do with a v8 powered 914 with auto trans my point was the fwd cadallic auto trans mission may be an option for a ls engine in a 914 or the northstar and trans might work out well too yhe northstar is a pretty small engine making 300 plus hp stock
jerry
JM Motorsports
81 911 SC ,black
73 914 V8 LS1
Old 04-04-2014, 09:22 PM
