Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
A&F A&F is offline
Radiator Placement Options/Question
I've been reading several builds on this form as I am looking for radiator options.
I've noticed many guys cut out a large swath of the front tube and put in a custom gas tank with a large radiator laying flat. This is then vented under the car.
Does venting this air under the car cause stability issues with the aerodynamics?
Also, I noticed that Rod Simpson has a kit for $850. He claims that there only needs to be a small hole cut in the nose of the tube to use his radiator. The existing gas tank can then still be used. How does his setup vent the air? I can't seem to find any pictures of it other than this one.
He also lists a heatercore for $80. Does anyone know what this looks like? What is Renegade supplying? Jegs sells this unit for $150. It looks perfect, blower included and two exits. I could just hook up the existing heat boxes too it and use the 3-speed console switch to power the fan.
Old 01-26-2015, 09:22 AM
lin7310948's Avatar
my radiator i placed at approximately 45 degrees in the front nose of my 930 and vents beneath the car. i do not track the car but have seen some substantial speed and the car feels very well planted on the highway. i would never consider placement other than as it is. reversing is not difficult...just weld the nose bulkhead back in place. my car does not run hot but i did have the radiator made to my specs....much larger than r hybrids. my grill opening is rather small as it is a Ruf yellowbird spoiler for a 930.
69 bronco..... 91 mustang ssp santa clara county sheriff's office ...2017 focus rs tuned on 93 400 chp
Old 01-28-2015, 05:06 PM
A&F A&F is offline
Are you still running the front AC condensors?
Old 01-30-2015, 07:52 AM
lin7310948's Avatar
no radio no air no frills bout 2300 pounds!
Old 01-30-2015, 09:16 AM
Gas Huffer
MichiganMike's Avatar
I went the same route as PVX did on his GT3 car. Two custom radiators in the front fenders with 2 fans on each. Keeps the stock look and doesn't cut out any metal what so ever!
PVX build thread: one view from the slope
Help me style this beat-up old 912
67 Porsche 912R-STi - Betty White - Instagram: @912RSTi
69 Porsche 911T - Project
04 Ford F-150 FX4 - Boris
Old 09-17-2015, 11:14 AM
