Hi guys !
I need the oil pressure and coolant temp sending units with correct VDO output. Any input please ? Already contacted renegade hybrids. Thanks DOHC |
Well the factory oil sending unit is part number 928 606 203 04 which I think should get that going... but which gauge are you using for "coolant", oil temp? If so the part number you seek for the oil temp sensor is 911 606 112 00. I guess you could plumb it into the block and the gauge wouldn't know the difference in what it was measuring
![]() Hope this helps. J
John~ 2003 996 Turbo... 128K Daily-ish 2000 Accord V6... 275K - 65K motor/trans now given new life! |
Thanks ! Got my info from Steve of RH. If anybody wants the info I'll post it.
Dohc |
Thread Tools | |
Rate This Thread | |
