Go Back   Pelican Parts Forums > Porsche Forums > Porsche Engine Conversion Tech Forum
1.8t powered 924s
I have a pair of 87 924s
One on The road and the other with issues I've picked up a low miles Jetta 1.8t for cheap with body issues to part but would like to put the engine in the car with issues for a track day toy. Have seen a few pictures of cars that have been done but not alote of details on issues that I know will come up is there a build thread on here that I just didn't find?
Old 03-28-2017, 06:13 PM
jadewombat's Avatar
I haven't see one in here, there's others on the interwebs.
'66 11-window VW Bus (Fuel-injecter'd Super-1600, IRS, disk brakes, MB CLK rims)
Old 03-31-2017, 02:54 PM
Seen a couple but not alote of details or stopped posting half way finding as much as I can so I'm ready and don't have to look or wait for parts
Old 03-31-2017, 06:01 PM
jadewombat's Avatar
Honestly, if you don't have the time or patience, then don't even start on a project like this.
Every single guy out there who's done an engine swap has had to deal with some issue that doesn't have a mapped out solution on the interwebs. Fitting a motronic 1.8T can will pose a lot of fabrication challenges to getting a near 40 year old 924 back on the road (error codes/gauge display?, stock 924s ran hot--->cooling solutions?, clearance issues of the hood and engine bay, exhaust mating?, etc.).
I'd sell the 924s and the Jetta then just look out for a 924/944 that someone has already built up.
Old 04-02-2017, 11:00 AM
Not a new guy with fabrication, finishing up a long project, 89gti ABF turbo build with standalone. I would say same thing to someone I didn't know.
Old 04-03-2017, 02:44 PM
A few have been finished and are driving.
The hard part seems to be mating engine to trans.
A few have gotten a FWD 1.8 transaxle and cut it up/machined a BH out of it and then made an adapter plate to bolt between the "BH" and the 944 torque tube.
There is a Quicktime brand steel bellhousing available for the 1.8 for about $700 but then you still need to make an adapter to the 944 tube.
Engine fits very easily as it is super compact - mounts are the "easy part". From what I've seen it's either custom intake manifold or modified B5 Passat intake manifold with the throttle body moved a bit to clear 944 brake master cylinder.
Old 04-05-2017, 01:44 PM
New email and forgot login password so set up new account, update made custom adapter, engine is mounted to torque tube and working on mounts tonight😈
Old 06-06-2018, 05:40 PM
Old 06-06-2018, 05:43 PM
More pics on Instagram Donald.stevens.96
Old 06-06-2018, 05:46 PM
Passat turbo fits best
Old 06-07-2018, 02:57 PM
Very neat! Keep it up the Good work!
Old 06-11-2018, 10:21 AM
Busy week but got some mounts started
Old 06-16-2018, 07:26 PM
Any updates? Really interested. Clutch just gave out and have a few other things that need replacing. Motor has close to 200K miles and not as effective as it once was. Considering this option.
Old 07-13-2018, 10:13 AM
Been busy with new job finished up one mount and other is ready to be welded but haven't been able to get gas for welder
Also researching the BMW brake hydroboost so I don't have to find someone to tig the intake, I may be able to use a jetta intake
Old 07-26-2018, 05:34 AM
Thinking it would be close to fitting with hydro booster
Old 07-26-2018, 02:52 PM
jadewombat's Avatar
You've seen this? It looks like they went non-power brakes to get everything to fit.
Motor Werks Racing Porsche 944 1.8T Engine Conversion — Motor Werks Racing
Old 07-29-2018, 12:49 PM
Ls swaps gave me the idea its a must to fit the ls in
Old 07-30-2018, 06:15 PM
FrenchToast's Avatar
So many OEM applications of that engine, both transverse and longitudinal. There must be an off-the-shelf one that works? There are a few aftermarket intakes for it too I'm sure, try 034motorsport.
Old 08-02-2018, 06:07 PM
I wish haven't found one, did some measuring last night need to tilt engine a little to pasengerside for water pump clearance, making about her adapter plate this weekend hopefully.
Old 08-03-2018, 10:20 AM
