1971 911T Small Block rescue
Hi all,
I'm new to the Porsche world and just picked up a small block Chevy swapped 911T from a local auction here in Toronto, Canada. ![]() It's obvious to me the car has been sitting for some time (not outside) and in it's current state it's what I would consider undriveable, even though everything is working. My current goal is to get it running properly and getting it driving properly, it's terrible right now. I only took it around the block and was afraid to take it any further. This is what I know so far: Edelbrock 45720 crate motor Edelbrock ProFlo / Weber fuel injection system Stock 901 5 speed Ruf bumpers and mirrors Not sure where the swap kit came from, I'm pretty certain it's not Renegade, it's using a motor plate of some sort and the front cooling is not what I have seen the renegade conversion use. looking from the top down to show the motor plate: ![]() Cooling from the top: ![]() This photo is with the top cover lifted up and you can see the rad housing, fans and where the front tub was cut out for airflow. I plan to document everything I find and fix om my 911T on this forum so this could turn into a long thread. |
Administrator
Hello and welcome to the forum! I imagine that some of our members may have experience with these kinds of swaps. Is the plan to keep it the way it is and get it running properly or are you looking to eventually put a 911 motor back inside?
Thanks Dimitry.
I'm going to leave the Chevy in it for now. That engine is dyno'd at over 400HP. Not sure I'm going to ever put a mezger back in it, that is unless I can find a wrecked car for a decent price. If anything I was thinking of swapping in a complete 996 engine and trans. I'm a big fan of restomods. |
That’s a pretty scary cooling setup, as a lot of structural material was cut out for the fan exhausts. That combined with the extra load and torque of a Chevy engine is not good. I’d seriously reevaluate the front tub, and try to replace the material that was cut out.
Second, the 901 trans is not going to last long with the kind of torque the Chevy puts out. It’s going to take some work, but a Subaru 5 speed might be your cheapest route to a transmission that can survive that kind of torque. A 930 4 speed would be the best choice, but they’re insanely expensive. Sent from my iPad using Tapatalk Pro |
![]() I don't believe it affected the integrity that much, but I have many other issues to deal with that are bigger. on this car. I'm in process of setting up my garage to work on the car so no progress has been made unfortunately since I acquired the car and to top it off, I bought another parts car (1985 Targa with a 3.2 that was in a fire) I'll be parting much of it out as I certainly don't need everything on it. The Garage build requires a thread of it's own. |
Thread Tools | |
Rate This Thread | |
