Another SC Engine Value thread
Considering jumping ship on the 3.0 in my 81 SC to go 3.6. Was wondering what you guys think I could get for it.
81 SC 3.0 Engine 168k miles, no record of rebuild Runs very well when warm. Cold starts are a bit rough, thinking injector O-Rings need replacement. Work done over winter, less than 1,000 miles ago: Valve adjustment New clutch/flywheel New spark plugs New 90A alternator, power wire, alternator strap New fan, fan housing, fan housing extension, pulleys New Rear Main Seal Resealed Crankcase Breather housing New breather hoses New Oil Pressure Sender New Tstat O-Ring AC removed With 2K miles New M&K Exhaust New Fabspeed Cat delete Oil and Filter Would be selling long block with all CIS. I was thinking maybe 9-10K? or is that optimistic?
1981 911SC Last edited by PushinRice; 09-16-2018 at 04:54 PM.. |
gearhead
Yeah, $8-10k
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Thanks, I figured I would be in that range 👍🏼
1981 911SC |
Hopefully someone can get in there and replace all the studs and be back in business.
Mahle P/Cs or KS Alusils? To me, if they have KS then minus $2K Once you get bit by old Alusils, you tend not to forget and wish Mahle on everyone. |
Still here
Head damage would be another factor with two broken studs.
It's confusing because Mahle also made Alusil. If it has KS on the base with ten fins, it's Alusil. Who knows? Almost all '82 and '83 engines had Alusil, so you may be lucky. |
With broken head studs?!?
What is a similar engine in good working order worth? 5-8k more?
_______________________________ 1982 911 SC 240,000mi and counting |
Eva
Just about
'78 SC Targa ~Brynhild~ Insta: @911saucy "The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman- |
Still here
I say $6K tops.
Personally been in the market this summer for one.
I would estimate $6k -$7k for an engine needing studs with the miles and no history. Partially as you don’t know what else you might find. You can ask more, I think you would get it, but I’m not sure it would sell quickly. $10k will buy you a fair and running sc engine with some history if you are quick enough to be the one to pick it up. That seems to be the magic number. Some seem to go up to $14k or $15k but then they tend to sit around. So with it needing work, my call would be $7.5k if you want to sell it reasonably quickly and be prepared to negotiate a little. For me, in the end, I found a car with a nice engine with the intention of dropping that into my project. Only problem is, it turned out to be a really great car. I did get to drive it before buying too which for me is a plus. Thought about seeing if whoever your getting your engine from might be interesting in trading? Most of the traders out there will either do the studs or have contacts that will and therefore not such a worry for them. Edit, maybe a little more as I didn’t read the new m&k on it.
Have I disabled cookies? Well I’ve eaten the heads off a few gingerbread men... Last edited by Munky King; 09-02-2018 at 02:05 PM.. |
Still here
You can also get more parting it out into the long block and accessories but then you do more work. Last edited by pmax; 09-02-2018 at 02:53 PM.. |
