Another SC Engine Value thread
Considering jumping ship on the 3.0 in my 81 SC to go 3.6. Was wondering what you guys think I could get for it.
81 SC 3.0 Engine
168k miles, no record of rebuild
Runs very well when warm. Cold starts are a bit rough, thinking injector O-Rings need replacement.
Work done over winter, less than 1,000 miles ago:
Valve adjustment
New clutch/flywheel
New spark plugs
New 90A alternator, power wire, alternator strap
New fan, fan housing, fan housing extension, pulleys
New Rear Main Seal
Resealed Crankcase Breather housing
New breather hoses
New Oil Pressure Sender
New Tstat O-Ring
AC removed
With 2K miles
New M&K Exhaust
New Fabspeed Cat delete
Oil and Filter
Would be selling long block with all CIS. I was thinking maybe 9-10K? or is that optimistic?
1981 911SC
Old 08-21-2018, 08:08 AM
gearhead
Yeah, $8-10k
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 08-21-2018, 08:30 AM
Thanks, I figured I would be in that range 👍🏼
1981 911SC
Old 08-21-2018, 03:08 PM
SalParadise's Avatar
Hopefully someone can get in there and replace all the studs and be back in business.
Mahle P/Cs or KS Alusils? To me, if they have KS then minus $2K
Once you get bit by old Alusils, you tend not to forget and wish Mahle on everyone.
Old 08-21-2018, 03:51 PM
Still here
pmax's Avatar
Head damage would be another factor with two broken studs.
Old 08-21-2018, 05:08 PM
Originally Posted by PushinRice View Post
Not sure about cylinders.. the engine hasn’t been opened up and I don’t think I would be able to tell from the outside.
You can tell from the outside. Just count the cooling fins. Ten fins make it Alusil, and eleven make it Nikisil.
It's confusing because Mahle also made Alusil. If it has KS on the base with ten fins, it's Alusil.
Who knows? Almost all '82 and '83 engines had Alusil, so you may be lucky.
Old 08-21-2018, 05:38 PM
Originally Posted by Matt Monson View Post
Yeah, $8-10k
With broken head studs?!?
What is a similar engine in good working order worth? 5-8k more?
_______________________________
1982 911 SC 240,000mi and counting
Old 08-21-2018, 06:39 PM
Eva
911SauCy's Avatar
Just about
'78 SC Targa ~Brynhild~ Insta: @911saucy
"The car has been the cave wall on which Industrial Man has painted his longings and desires." -Eddie Alterman-
Old 08-28-2018, 05:32 PM
Still here
pmax's Avatar
I say $6K tops.
Old 08-28-2018, 07:17 PM
Munky King's Avatar
Personally been in the market this summer for one.
I would estimate $6k -$7k for an engine needing studs with the miles and no history. Partially as you don’t know what else you might find.
You can ask more, I think you would get it, but I’m not sure it would sell quickly.
$10k will buy you a fair and running sc engine with some history if you are quick enough to be the one to pick it up. That seems to be the magic number. Some seem to go up to $14k or $15k but then they tend to sit around.
So with it needing work, my call would be $7.5k if you want to sell it reasonably quickly and be prepared to negotiate a little.
For me, in the end, I found a car with a nice engine with the intention of dropping that into my project. Only problem is, it turned out to be a really great car. I did get to drive it before buying too which for me is a plus.
Thought about seeing if whoever your getting your engine from might be interesting in trading? Most of the traders out there will either do the studs or have contacts that will and therefore not such a worry for them.
Edit, maybe a little more as I didn’t read the new m&k on it.
Have I disabled cookies? Well I’ve eaten the heads off a few gingerbread men...
Old 09-02-2018, 02:00 PM
Still here
pmax's Avatar
$6k seems light IMO. I see long block cores for sale for $5k+, not sure what they end up selling for. I’d think a complete running engine with all accessories would fetch more.
If you can confirm it has Mahle's as another posted suggested, I will bump up my estimate.
You can also get more parting it out into the long block and accessories but then you do more work.
Old 09-02-2018, 02:46 PM
