help needed determining value of 912
Hi, I'm going to look at a 1966 912 tomorrow. The owner states no motor/interior. Body work has been finished about 15-20 years ago and is in primer. It has rear flares added along with converting the rear to look like an 80's SC. It also is convertible. I'm guessing it was originally a targa. So its a rolling shell without "rot". I'm just trying to gauge some sort of value. (I know its hard without seeing it)
What are you going to use it for? How much would you pay for a roller coupe or targa? How much will you be "undoing" ? Its a hodgepodge for sure. I have no idea what a 912 vin roller runs these days, but maybe $1500?
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
I just found out if was converted from Coupe to convertible. Hes asking 5k for the rolling shell which has the body work complete.
What is your goal in purchasing this roller? You'll end up spending $25k to make it a daily driver.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Troll Hunter
I'm assuming it needs everything. $25K is $15K too low IMO.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
I was wondering how a roller turns into a daily driver for 25k as well. These are all value traps as far as I’m concerned. It’ll cost more getting it road worthy than to just buy one that already is road worthy, yet the allure of buying it so cheap is what sucks people in to take on the project. It’s for one that’s a glutton for punishment, that’s for sure.
gearhead
911dreams, as others have alluded to, this is likely to end in tears.
If all the underpinnings are there; brakes, suspension, etc, he will get $5k for it. The only way this works out somewhat financially sound is if you have a complete running rust bucket to build onto it. I keep hoping to stumble onto the right roller. I’ve got a 75 targa that would be a great donor car. The chassis is too far gone to bother fixing but she runs like a top.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
The car was trashed. The convertible conversion was an embarrassment and the body work was done poorly. I passed on the car because I didn’t want to insult him. I probably would have bought it just to part it out which would barely be worth it
Good call. Unless you’re a salvage yard these are rarely worth your time, even for parts, and they carry negative value in terms of a restoration project. Buy one that runs and be thankful you dodged a headache.
