Doug
COA ... numbers matching info NLA?
Tell me it ain't so!
I have a 1969 911T highly original low miles.
I am fairly confident that the engine and trans are number matching. I do not have a COA or a Kardex. Shoulda done it years ago but, DUH!
And, now I hear the COA no longer comes with the eng / trans numbers.
I have heard that if I PROVIDE the number of eng / trans then if CORRECT the coa certificate will print those number on the certificate.
True / False ?
I want to know for sure if this is a numbers matching car.
What is the best way to get this info now?
And if coa will not verify the numbers will a kardex do the trick?
Thanks for your input.
Doug
Old 10-13-2019, 07:29 PM
True / False ?
Doug
I’ve been told the only way now is to go to one of the 8? Porsche Classic dealers and pay them a small chunk of money to do an inspection on your car. One of the things they do is report your engine and trans numbers to Porsche of America and they will then in turn print the numbers on a COA I believe. Fun!
Old 10-13-2019, 09:04 PM
War Vet
matt930s's Avatar
Several years ago, I called Porsche to verify my 911e (engine and Ronnie); I had to fax them a copy of the title and my DL. They called me back with the numbers for my 69.
Not sure if they still do that.
MattR
Dr. Phatt
Old 10-14-2019, 06:36 AM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
That special wishes gearbox probably added at least $25k to your car's overall value, bisch!!!
Old 10-14-2019, 10:09 AM
Ok
You can buy a book telling us VIN numbers to the engine and transmission
This will tell you a range of engines vs the range of VIN numbers
Start with that and if in the ranges it’s very likely matching
I used the book in the days when looking at cars because the COA was $100
Very unlikely someone would install a engine in the correct range to the VIN
But. In later cars the vin and engine numbers are on the hood sicker
Old 10-14-2019, 01:42 PM
Home of the Whopper
MattR
I went through something similar last year.
PCNA wouldn't give me the numbers, but they did verify the numbers I provided.
1968 912 coupe
1971 911E Targa rustbucket
1972 914 1.7
1987 924S
Old 10-14-2019, 02:06 PM
Originally Posted by wgwollet View Post
Ok
Negative Ghostrider. It’s very very common for people to have the correct year and series type as the next best thing to the original. I have 4 cars personally that are all missing their original motors but have the correct year and type so that’s a big fat no sorry to say. Which cars have a sticker under the hood with the engine number on it?
Old 10-14-2019, 05:17 PM
It’s all changed now. My first comment above is the only way now as I understand it
Old 10-14-2019, 05:18 PM
Doug
Thanks for all the responses regarding the COA. I will see if I can find a workaround.
- Doug
Old 10-14-2019, 07:36 PM
gearhead
Yep. Seen it more times than I have toes and fingers. Same reason I have a 1974 911/83 case in my garage with the number scraped off it. Someone wanted to make it look like a replacement case for a car that had lost its original. I bought it after the car owner found his original and reunited them.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 10-15-2019, 04:53 AM
I believe the classic P delear inspection/ # verification is now $500.
Old 10-15-2019, 07:29 AM
High Hope's Avatar
I provided the engine and transmission numbers from my 356 on the “CoA” application (it’s called something else) and the certificate came back as “matching numbers” w/appropriate numbers listed.
An earlier experience w a different car (911) sent PCA the same data, I got a call that the numbers weren’t matching, and did I still want to pay for the certificate. I agreed, and the certificate listed “information not verified,” which I knew already.
Old 10-16-2019, 02:35 PM
Unfortunately this is already the old process. They will no longer confirm numbers such as they did on your 356 without it going to a porsche classic dealer and having an inspection
Old 10-16-2019, 04:58 PM
NIGHTMARE! PORSCHE scamming their base.
NIGHTMARE! PORSCHE scamming their base. Dig into this to understand what they've done to everyone. Sarah is usually on that would help everyone at the COA dept. NO LONGER!
Classic Technical Certificate (CTC) which is a comprehensive certificate providing important production information and technical specifications of your Porsche. For information regarding the CTC, please visit the below website.
https://www.porsche.com/usa/accessoriesandservices/porscheservice/vehicleinformation
coa@porsche.us
Sara Edie
Porsche Specialist, Certificate of Authenticity
Porsche Cars North America, Inc.
One Porsche Drive
Atlanta, GA 30354-9817
Old 10-17-2019, 03:14 AM
Someone should start at threat "Boycott Classic Technical Certificate (CTC)" See who in on this...
Old 10-17-2019, 03:18 AM
techweenie's Avatar
Hey, Wintersurf! Fish around for anyone offering a Kardex. It's a 'backdoor' service that requires some... um, rewards to insiders, but your 69 is the last year the Kardex was used, and it's far more accurate and valuable than the old CoA was.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 10-17-2019, 08:54 AM
Cobalt's Avatar
That is correct. They will do a full inspection of the car and report its issues as condition in a nicely printed document in a folder. It is several pages of info but they will not make note of originality and will just state if the engine and trans numbers are within range for that MY of car.
A lot of BS if you ask me.
Anthony PCA affiliate '77 member '83 '90 3.8 RS tribute, 91 C4 converted to C2,'93 964 C2, '93 928 GTS M '94 Turbo 3.6, '15 Boxster GTS M,16 GT4,23 Macan GTS,
Gone worth mentioning '71 E '79 SC, '79 built to '74 3.0 RS tribute (2390 # 270 hp), '80 928 euro 5 speed, '74 2.0l 914, '89 944 S2,'04 Cayenne TT '14 boxster, '14 Cayenne GTS 14 Cayman S, 18 Macan GTS many others
Old 10-17-2019, 09:18 AM
High Hope's Avatar
This looks like a lot of "lawyering up" by Porsche, especially for the litigious US. I can imagine more than one lawsuit cropping up over a factory statement of originality and a purported "original matching numbers" car being disputed as a result.
Old 10-17-2019, 10:37 AM
techweenie's Avatar
'numbers within range?'
Any one of us could do that with 10 minutes of googling...
1969 coupe hot rod
Old 10-17-2019, 11:01 AM
specialtyoneinc's Avatar
Since values have increased and fraud is definitely out there, I don't think Porsche AG wants to get involved in any lawsuits.
Old 10-17-2019, 11:04 AM
