Ever jump a Porsche?....
Value of a disassembled 3.2?
Ok,
I have a complete 3.2 engine with the exception of a few minor bits on the intake available that I could sell. When I got the engine I was unsure of the condition so I tore it down. Inside looked fantastic. It must have been a low milage car. So the dilema I face now is how to sell it? do I rebuild it and sell the engine as a whole? or do I sell it as is? I have several engine projects in the works and don't really need it right now. I would think the value would be pretty good since you can see the internals and know the condition of the parts... What kind of value should I put on it?
Casey Road-rally, Targa Newfoundland junkie!!! 1969 RSR 3.4L PCA class GT-3 (in progress)...1800 lbs and dropping Thinking of driving in TARGA NEWFOUNDLAND? Contact me and I can help answer your questions. The event is awesome! |
If you can assure the buyer you have kept track of the parts and where they go, I would think around 5000 less one day labor and a gasket set to reassemble. The key is that you know which rocker went where and which bearing, etc. I emphasize "without a doubt."
Sounds like a good oportunity for someone. I'd buy it if I had a car to put it in. ![]() |
Thanks.
That was about in-line with what I was thinking of listing it at. Bummer in a way because I was floored by the excellent condition of the heads. I cleaned one up and found that virgin-type condition as a racer you are always trying to get. So a used, unknown 3.2 goes for $5500 and a very clean disassembled one goes for about $1000 less. I'll need to think about this some more. I could use the crank in another project, but don't need anything else. So if I parted it out, what about these prices? Case: $1200 Crank: $1500 Intake: $600 Heads: $800 Cams: $400 P/C: $600 rods: $200 cam towers & tensioners: $200 oil pump: $300 Misc stuff: $400 That puts the parts at $6200. hmm. where was I too high? Even a conservative number would be $5000 for good, clean parts. Yeah, I wish I had a car for this to go in too. Too many engines!
