How Many 4 Speeds?
Back in the late 60's and early 70's 4 speeds were standard and 5 speeds were an option. Is there any info on how many 4 speeds and 5 speeds were actually produced for each year. I notice most early 911's being advertised are 5 speeds, rarely do you see a 4 speed.
This may be a stupid question but I also noticed that the ratio's for 1st and 4th on a 4 speed and the same as 1st and 5th on a 5 speed. So other than during accelleration is there any advantage to the 5 speed. I assume since the ratios for the top gear are the same the rpm's would also be the same say when freeway/highway driving? Or maybe the rear axle was different? Thanks |
gearhead
The US was the largest market back then with more than half of the cars coming here. Americans wouldn't buy a sportscar with a 4spd gearbox, so most dealers optioned the cars as 5spds when ordering their stock.
You see a fair number of 912s with 4spds, but in general, most North American 65-73 911s got 5spds. If anyone has an idea on the numbers it would be Dave Pateman. I suspect he'll see this thread within a day... 5spd offered better acceleration. That is the sole advantage. Both the 4spd and 5spd got the same 7:31 ring and pinion. The exception is the 1969 912, which got a 5spd with a short ratio 6:29 ring and pinion. Pretty rare gearset these days. Some racers like them, but they wear out quickly. They are also a different size differential so they take a really super rare LSD to make them a proper racing final drive. The factory used them for hill climb cars.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
Thanks Matt. Hopefully we will hear from Dave Pateman.
If the only advantage between the 4 and 5 speeds was acceleration, would the 4 speed not have been faster as you would have had fewer gears to pass through to get up to speed? |
More of a factor on a road course where gear selection is more critical to acceleration off a corner.
Chet Dawes 1971 Porsche 911T Coupe 1974 Porsche 914 2.0L 2004 BMW 330i ZHP Sedan 2008 BMW X5 4.8i Sport |
So I guess there is no data on how many 4 and 5 speeds were produced?
Not sure about the data, but besides 912s, 911T's would have come with a 4spd unless optioned with a 5speed. Many 4spd T's have subsequently been converted to 5spd cars.
Suprisingly, a few years back when I considered a longhood I came across TWO 4spd T's.
1970 914-6 Past: 2000 Boxster 2.7, 1987 944, 1987 924S 1978 911SC, 1976 914 2.0, 1970 914 w/2056 |
