Fender question
I bought a 91 targa shell . Will the fender lips match if I put them on a 68 widebody T that I want to turn back to stock ?
Thanks, you guys are a great resource . I have cars - I need knowledge. Thanks again . Brian vb
Old 02-02-2015, 08:53 AM
A 964 shell to use the fenders on a '68? No, it won't match. Wait for some stock fenders if they ever come up. Even impact car front fenders vary quite a bit through the years though they all are supposed to 'fit'.
Old 02-02-2015, 09:41 AM
pors1968's Avatar
You have to use 65-68 front fender they have no flair .Briand you have 1968 S soofwindow macthing number that +100k car buy two new quater and front fender.
Old 02-02-2015, 03:31 PM
Please take this good advice!
Find used /new fenders for a SWB 911 and not re-bastardize the car, otherwise you are only making a sideways change and not an improvement to show for your work and money outlay.
Old 02-02-2015, 04:39 PM
Ok Thanks. I have a 68t dressed up to look like an 89 turbo = yuk ! I want it to go back.
Re: My 68s widebody, I signed a contract promising the guy that sold it to me to never cut the fenders off. To bad for me.
Old 02-02-2015, 10:16 PM
Surprisingly, I also need front fenders for my 79 930 which is slanted, and shouldn't be.
Old 02-02-2015, 10:25 PM
Well, you have front fenders for your 930 already on your 68T with the 89 turbo look, that is a good start for undoing the crazy ideas of the time.
Sounds like you have some fun cars
Old 02-03-2015, 04:38 AM
Neat suggestion. My 79 930 is wicked and the 68t is a POS. I'll check but I'm sure the 68t will have copious bondo. I need my 79 930 to be perfect so I'll try to find perfect fenders. Does the 79 factory front fenders have welding ? Or are the built "flared" ?
As usual, thank you for all helpful comments.
Old 02-03-2015, 08:23 AM
techweenie's Avatar
There is little real "flare" difference between SWB and LWB. It's just the outer lip that sticks out maybe 10mm more in the later cars.
Very important to note: if you are doing a high quality 'rightdate' on your 68, be aware the 68 front fenders are one year only configuration.
If you look at the wheel well openings from underneath, the inner edge of the lip is trimmed away toward the center on a 68 fender. The flange is of consistent thickness on 65-67 fenders that otherwise appear the same.
Also, if you haven't shopped for early fenders before, all SWB fenders have "boxed" areas for the turn signal assembly and all LWB fenders have open areas.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 02-03-2015, 08:57 AM
They were welded on flares for sure in 1979 from the factory.
Old 02-03-2015, 10:07 AM
