Question Chirrrrrrp
Driving my car last night, I noticed a chirping noise emanating from the engine compartment during 3/4 throttle at higher rpm prior to a shift. I'm suspecting the Bosh blue coil or the Crane XR700 mounted to the firewall based on previous posts. Any thoughts? Thanks.
Old 11-20-2002, 10:46 AM
Unregistered
sammyg2's Avatar
Is it carbureted?
Old 11-20-2002, 11:49 AM
Stock 1974 2.0 FI
Old 11-20-2002, 01:15 PM
bernbomb914's Avatar
chirrrrrp
Check the thru-out bearing or rear carrier bearings they could be the culprt.
May all your shifts be true
Chrome Yellow 74 1.8 Beauty
black 74 1.8 project car
2002 Land Rover Disco
2002 Astro Van
32' motor home
Old 11-20-2002, 01:37 PM
norustscott's Avatar
I have some simple stuff
>check the alternator fan belt...loose?
>check the distributor cam...Dry?
>check evrything sheet metal...loose?
Scott
1982 911 SC
1962 sunroof bug
1991 WE Vanagon CARAT WRX conversion
Old 11-20-2002, 02:16 PM
JWest's Avatar
Maybe you have the ultra-rare "Coal Miner Edition" 914 (usually installed on yellow cars). In this case you will be happy to know that you are not being starved for air while driving.
If the chirping should quit, you need to first check the canary (I think they were usually clamped next the battery tray, but with rust over the years you don't know where the PO may have moved it).
The next check is NOT the heat exchangers, because we know they all leak. What you need to check is to make sure the seals for the top and windows are OK, and operating as a "passenger air comfort system" like originally designed.
If they are defective, then rain will not come in and you will hear no wind noise. A proper 914 top seal will let a good-sized water drop hit the driver in the foehead at a critical moment in traffic.
Also, the alternate "wind speedometer" should be working properly. Each ten MPH increase in speed should bring a new and distinct whistle from various parts of the top and side windows.
Good luck.
James
JWest Engineering
Old 11-20-2002, 02:33 PM
Potter's Avatar
Send a message via AIM to Potter
Sir, I applaud you. THAT was beautiful.
'73 914 2.0
"Seriously Honey, the part was really really cheap...........honestly"
Old 11-20-2002, 03:37 PM
Barber Dave's Avatar
my car
James ; How the heck did you get my 914 out of storage and drive it around . Very cute! Put it back now!!!!!! Dave
Old 11-20-2002, 04:29 PM
