dickster's Avatar
idiots guide to momo prototipo install in a carrera
(start by centreing the wheels) remove old wheel. prise off horn pad, and remove nut.
you're left with this
remove horn ring/indicator (repeater) cancel from bottom of old wheel
Rich
'86 coupe
"there you are"
Old 12-06-2003, 12:38 AM
dickster's Avatar
new bits to go on
place the piece from the bottom of old wheel to bottom of new hub (3 screws supplied are a little small)
cut off old small spade connector (new fitting indicates larger size) i left part of the spade there for fixing into block connector
Rich
'86 coupe
"there you are"
Old 12-06-2003, 12:41 AM
dickster's Avatar
fit new hub to column. line up repeater cancel plastic stub with repeater stalk, while keeping centre the top hole for the steering wheel - the repeater cancel was slightly off, but still works. torque hub nut to steering column (dont forget washer) to 50nm - dont have lbs to hand.
fit wheel (note the ring (see pic of all the bits) fits between wheel and hub adaptor - has a spade connector that i didnt need, but it forms the mount and earth for the horn push - mount the ring so that its male spade is on the opposite side of the wheel to the one on the horn push otherwise they may foul each other)
wiring and fittings for horn push
Rich
'86 coupe
"there you are"
Old 12-06-2003, 12:47 AM
dickster's Avatar
connect wire for horn push with a block.
fit horn push. carefully push into place and make sure clips are not binding/catching - i used a small screwdriver to very carefully push the earth wire clip in.
thats it 45 mins work.
Rich
'86 coupe
"there you are"
Old 12-06-2003, 12:51 AM
dickster's Avatar
before
after
Rich
'86 coupe
"there you are"
Old 12-06-2003, 12:58 AM
dickster's Avatar
couple more
Rich
'86 coupe
"there you are"
Old 12-06-2003, 01:01 AM
AirCooledExcellence's Avatar
Nice job Rich!
Good looking wheel that, I think I'll stick one on my xmas list!
Cheers,
Tim.
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 12-06-2003, 01:18 AM
Great job Rich--good writeup too. I put a Momo wheel on my car and its funny how such a simple job can turn into a mess (in my case anyway--I drove around without a horn and no blinker shutoff for a week...so thats what those extra parts are for).
1980 911SC Targa 3.6L
Old 12-06-2003, 04:34 AM
dickster's Avatar
cheers, i think it makes the cabin more "business" like.
john, i know what you mean, i cannot believe they dont provide instruction - still thats the reason for the thread.
actually, maybe it is for safety reasons that they dont........
Rich
'86 coupe
"there you are"
Old 12-06-2003, 11:10 AM
Thanks for the guide Rich! Just put it to good use over my lunch break:
Had to 'persuade' the hub to fit the steering wheel shaft a bit though! Did you have to as well?
Cheers,
Tim.
1987 930 - SOLD
Old 04-27-2004, 06:41 AM
mikester's Avatar
Send a message via AIM to mikester
Cheers,
Tim.
The steering wheel is on the wrong side of your car.
-The Mikester
I heart Boobies
Old 04-27-2004, 06:51 AM
TMH TMH is offline
TMH's Avatar
Rich,
Nice write-up. I have now been through this procedure a couple of times, and it gets easier each time. A couple more hints to go along with your article:
1) At the very beginning, remove the horn relay to better maintain the sanity of both you and your neighbors during the job.
2) Final step: Pry (or prise, if in the UK) the speedo out of the dash and rotate it such that "your" useful range of the dial is not underneath the (smaller) steering wheel rim.
Done and done!
Tom
Ain't life grand?
Old 04-27-2004, 07:39 AM
Don't forget that some us prefer to (also) use the small spacer, besides the hub adaptor. It moves the wheel further back towards you, but (more importantly perhaps) it maintains the stock wheel's "eccentricity" ( by mounting the wheel higher, when in the straight-ahead position). This gives a bit more visual room for the instruments.
---Wil Ferch
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-27-2004, 08:10 AM
Buy them, sell them
Adam's Avatar
Good write-up, Rich!
When I did mine (late at night at Matt Holcomb's place), when we installed the horn button, even with the ignition off, we woke up the neighbourhood with rampant "toot"-ing as it clipped into place.
It's amazing the transformation a good Momo makes. If I knew it was going to be as good as it is, I would have done it three years ago.
1931 Oakland Eight Special Saloon
1985 BMW E28 525e (Euro 528e)
1989 911 Carrera Sport 3.2 G50 Cabriolet
Old 04-27-2004, 03:42 PM
Nice!
Coupla questions:
Who sells the Porsche badge for the horn button, and what were the really early (911R etc) boss's like? Did they still have the concertina plastic sheath over them, or were they (I suspect) solid?
Thanks!
'72 911 T/E Silver Targa
Old 04-27-2004, 04:39 PM
Competition
Had to bang on mine a bit to to get it all the way down on the shaft. (Wait a minute, that didn't sound write!!)
Reverend Ray
84 Carrera Coupe "DAS-V2"
GruppeB #2119
Volvo V70SE-Wife mobile
Nissan Frontier-Home Depot mobile
Old 04-27-2004, 05:06 PM
dickster's Avatar
i'm a bit behind here!
so *edit* TIM, you finally got your wish - looks great. no banging required btw - must be an "SC" issue
matt, the horn push are quite readily available at suppliers - can't remember where i got mine - i think it was the wheel supplier. i have seen them on ebay as well. if you get stuck let me know and i'll try and dig out the invoice.
now that i've been using the wheel i can say that although it is heavier to use i love it.
thanks guys.
Rich
'86 coupe
"there you are"
Old 06-16-2004, 01:21 AM
Blimey a bit behind, you aint joking!
Still asleep as well apparently, the name's Tim not Chris!!
Cheers,
Tim.
1987 930 - SOLD
Old 06-16-2004, 01:32 AM
dickster's Avatar
TIM!!!
sorry about that - i sold some wheels on ebay and a bloke called Chris just came to pick them up! Thats the only excuse i've got.
Rich
'86 coupe
"there you are"
Old 06-16-2004, 01:40 AM
It must be nice to see more of your instruments! Where did you hide the air bag, under the horn button? Nice Job.
Old 06-16-2004, 04:20 AM
