Another RSR Clone Project - Update 8
I've had the car home now for a couple of weeks. Latest progress includes brush painting the underside with the same signal orange paint as on the body. I've also completed the installation of the suspension and brakes. Here's the latest pictures:
I am using the Elephant Racing polybronze bushings and monoballs all around with 23/31 hollow t-bars, JRZ raised spindle adjustable struts, aluminum cross member and rear control arms and Bilstein sport rear shocks. The installation of the polybronze and monoballs was a breeze. Chuck seems to have engineered a very good product. All of the reports I've read indicate that they will ride and handle as good as they look and installed. The only difficulty I had was the installation of the larger rear t-bars. The holes in the flared fenders did not line up perfectly with the t-bar openings in the body making for a very tight fit. Next I'll be tackling the rewiring and reinstallation of all of the electrcal components. The engine is out for machine work and should be ready for the reassembly in about 1 month. The gearbox with LSD and short gears is complete. I am still targetting to have the car ready for the Parade in Hershey and have registered to show it in the concours. Keep your comments and suggestions coming. They are part of the inspiration to complete the project on time. |
That looks so awesome! Keep us posted.
Wow. Its like my cars big, badass brother. See you in Hershey.
My ignition is retarded. |
Licensed User
Amazing project! Nice work!
Looks awsome! What is going in the back?
Chuck Moreland - elephantracing.com - vonnen.com |
wow! there are three things with this thread making me green with envy. in order of envy, from most to least:
1. sweet car project. 2. car lift 3. three car garage. despite this, please keep up with the updates.
poof! gone |
Better than Sex???
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
That is outstanding
Ed Hughes 2015 981 Cayman GTS 6 speed,Racing Yellow Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4 |
Insert Tag Line HERE.....
Simply AWESOME......
Are the rotor holes (cross drilled) on the other side pointing in the same direction? It looks like you have the right and left sides switched. On the left side of the car, (as shown) the holes should spiral backwards (or to the right) from the center.
Marc |
Senior Member
Amazing. Porsche painted some areas of the bottom matt black, so when you looked at the car from the side it would make the body under the rockers less prominent. You should do that. Perhaps someone with a concours original car can post the areas that should be black.
Driving member
Man that thing looks so clean it is almost a shame to dirty it by driving it on the road.
I did say almost though Looks awesome. I haven't really liked many cars in bright orange but that one is a beauty. Keep us posted.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Stunning.......
- as to the problem fitting the rear bars through the holes of the ( presumably added) rear flairs..... .....look at the Gunnar Racing site, where they say they insert a rod or broomstick in the TB inner mount, so that the stick pokes through the newly-added rear flairs as the flairs are fitted. They allude that if you don't do this....everything seemingly lines up but then ( Ta da !)...the TB's can't go through the body hole because it's off-center...arrgh! Wil
Wow... This is better than new !
this is the way of a perfect restauration ! bravo ! Ray
1960 356 BT-5 Aetna blue 1973 911 RS récréation 1960 VW panel Dove blue 1971 914 barn find ! |
1971 911E Targa
What a beauty!!
Thank you for keeping us updated. Looking forward to more.
All of you 911E owners, come join us at The 911E Registry at 911E.org |
Less than 100 posts and you come up with that crap? Go away. Never come back. You are a troll of the worst kind. (Interpretation: That car looks amazing! Shame on you for making me jealous.)
Warren Hall Student
That's so beautiful that I'm misty.
![]() The paint is awesome. Is it two stage or one stage. It looks like it might be two stage.
Bobby _____In memoriam_____ Warren Hall 1950 - 2008 _____"Early_S_Man"_____ |
Administrator
I don't think I'd be able to bring myself to drive it.
I'd just want to sit in the garage and stare.
Jack Olsen 1972 911 My new video about my garage. • A video from German TV about my 911 |
Thanks for all your comments. They keep me motivated.
Relative to your questions: The paint is Glasurit 2 stage urethane. I stripped the car except for the underside where I left the original undercoating. The body, trunk & engine compartments and fender wells were painted at Auto Associates. I used the same paint, unthinned, with the hardener mixed in to brush paint the underside. I constructed a psuedo paint booth in the garage using a window fan and some tarp to isolate the working bay. I've been studying the Gunnar restorations of RSR's and they paint the underside body color. I like the look of the orange underneath. The brake rotors are Zimmermans and are the same left and right. I don't know of any reason why they should not be. I can't think of any aerodynamic effect that would relate to the hole pattern and direction of rotation. Am I missing something? The engine will be a pump gas 3.0 lt based on a 1978 case. I'll be using ported twin plug heads with the original dizzy modified for twin plug by Gerry Woods, Mahle RSR 10.5:1 P&C's, GE-60 cams from John Daugherty, 46MM PMO's and RSR headers. I'm thinking about 300 HP with about 2000 lbs curb weight. |
Registered Cruiser
"...300 HP with about 2000 lbs curb weight."
AND its an orange longhood. Covet thy neighbors Porsche.
87' Carmine Red Carrera - Keeper 82' Silver SC - Sold 79' Gran Prix White SC - Sold 05' Black C2S - Daily driver I have never really completely understood anything. |
Oh My God, that is my freakin dream car, my absolute dream. In Orange too. I would LOVE to be putting that thing together one loving piece at a time.
Congratulations, it is great to know that there are guys that actually get to do the things many of us dream about. Total, total congrat's, enjoy the HELL out of it for all of us! Please show us pictures to completion and some final wallpaper-quality pix on some beautiful leafy winding road in the spring.
Dan in Pasadena '76 911S Sahara Beige/Cork |
