Viton or Teflon? Valve stem seals
Which is the better valve stem seal? I have looked all over the net, and want to know what the pros are using?
Green is Viton right. White teflon?
2000 VW TDI 224HP/400FT TQ. Pikes Peak World Record Holder 2007 "Fastest Diesel Car" 1973 Porsche 914/6 2.4L Engine rebuild in progress |
viton
As far as I know, the viton seals seem to be in a lot of applications.
84' Steelslantnose Cab. 1953 Dodge B-4-B-108" 90,127 miles 1953 Dodge B-4-C-116" 58,146 miles 1954 Dodge C-1-B8-108" 241V8 POLY 1973 Roadrunner 440-SIX-PACK* 1986 F-250 Super Cab-460 V8 tow Newest additions- Matching numbers 1973 340 Road Runner!! 1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles others... |
White Teflon = bad, they actually seal the stem too well? Bob at Anchor-Atlantic did my heads and cautioned against the use of the white seals.
'66 911 #304065 Irischgruen ‘96 993 Carrera 2 Polarsilber '81 R65 Ex-'71 911 PCA C-Stock Club Racer #806 (Sold 5/15/13) Ex-'88 Carrera (Sold 3/29/02) Ex-'91 Carrera 2 Cabriolet (Sold 8/20/04) Ex-'89 944 Turbo S (Sold 8/21/20) |
If the application calls for the white Teflon seals, I usually take a small triangle file and cut a tiny notch in the seal part (inside rim).
Then I install with the notch up. It gives just enough oil into the guide to lubricate without allowing smoking. Bob
Bob Hutson |
So the viton ones are the way to go I guess for the 911 valve guides?
Friend of Warren
That is what John Walker recommended and used when he rebuilt my heads.
Kurt V No more Porsches, but a revolving number of motorcycles. |
3 restos WIP = psycho
Teflon seals too well. My engine was just torn down and teflon were used. The valve guides were crap and I didn't even know it since the Teflon seals masked the issue by not letting any oil by. I got lucky; the teardown was elective and if this hadn't happened, there would have been major problems in the future.
- 1965 911 - 1969 911S - 1980 911SC Targa - 1979 930 |
also... I read on one of these valve seal threads.. that the Teflon were easier to install and that's why some shops like to use them...
My head rebuilder put in Teflon seals--should have them replaced with Viton?
The heads are still off, how much trouble is it to replace the seals? |
hey.. guys do we tell Tom to replace or leave the Teflon in?
Max Sluiter
Go Viton.
I would rather pay a little more in the increased oil consumption and put up with some smoke than over heat a valve due to lack of oil. The head could fall off and rattle around in the combustion chamber, messing the whole cylinder up. If it leaks a little oil, what's the big deal? You will eventually flush the oil by adding a little at a time and you will be aware that your top-end is getting lubrication. ![]()
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
Either one of the above scenarios isn't preferable. We seldom have a choice and instead should deal with the existing condition. Lube to the top end is good, but oil leakage into the chambers via the valve guides is hardly a consistent method of distribution. Sherwood |
Max Sluiter
I was being slightly fascetious (sp?).
![]() New Viton seals installed properly will not leak and will only allow a proper anti-wear film to penetrate to the valve. They will not seal "too well" as the Teflon does and the manganese bronze guides sometimes appear to. The Viton may wear quicker, at which point some oil will leak past the seals after sitting. I think it will only be a "healthy" amount of oil that gets past while the seals are in spec and if the engine is exercised enough and in the proper way.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance Last edited by Flieger; 07-25-2008 at 06:53 PM.. |
"I was being slightly fascetious (sp?)."
![]() Sherwood |
Try not, Do or Do not
We always use Teflon. We have engines that have lasted 260K miles using the old tried and true. I have seen too many broken Viton seals to feel they are worth the risk. Plus I hate an engine that smokes.
Heat is the enemy of valve stem not valve stem seals. When we are building high HP turbos we often run special guides with no seal but that is a different animal. Bottom line is that either seal will work and work well. Flip a coin .
Henry Schmidt SUPERTEC PERFORMANCE Ph: 760-728-3062 Email: supertec1@earthlink.net |
Great--I am thinking I am going to stick with the TEFLON since:
1.) my local mechanic also uses them and says that properly installed they work quite well... 2) I am reluctant to pull perfectly good seals out of the heads after the fact I think that might introduce additional opportunity for mistakes. Thanks to everyone for the help! |
I used Teflon on my 3.2L rebuild, but be careful during installation.
Alex ![]()
Its easier asking dumb questions than fixing dumb mistakes 1974 Porsche 911 Coupe, RSR Project 1976 Porsche 911 Targa, Black 1986 Porsche 911 Carrera, Black 2006 Porsche Cayenne S, Black |
So what is the trick to installing the teflon seals as opposed to other ones? Special tool or what?
