Go Back   Pelican Parts Forums > Porsche Forums > Porsche Autocross and Track Racing
ncseahawk's Avatar
Porsche Crest BEST Seats for Daily Use and AX/DE events
Pelicaners,
Help me out, what is the best cross over type seat for daily use and occassional, monthly AX use?
Cost is not the only issue but something I must consider on an Army salary.
1985 Carrera Under Modification (SOLD)
2003 Carrera 4S
Old 02-05-2008, 07:55 AM
KTL KTL is offline
Schleprock
KTL's Avatar
If your car is a daily driver, i'd consider a seat like the Recaro Speed/SRD, Sparco Torino, Cobra Daytona, Corbeau, etc. I had the Recaro SRD and it was very comfortable and worked perfectly with 6 point harnesses. The only thing I didn't like is the seat bottom was not long enough (front to back) to give me good support underneath my legs in the area just above the knee. I have rather long legs, so other people may not have this problem.
The first three mentioned are a little expensive, but with the right sliders they'll bolt right into your car. When you go with a true racing shell, the width of the base is much narrower and you have to used some bracketing to fit the seat to the mounting rails in the car.
Kevin L
'86 Carrera "Larry"
Old 02-05-2008, 10:06 AM
#29 SCWDP (muhaahhh!!)
Gene Wilkes's Avatar
Take a look at these http://hunsakersports.com/shop/item.asp?itemid=194
I have a pair and have been VERY happy! Pics on my website!
IslandmanFL
SOLD...78 911SC (ROW) cabriolet/widebody
hear BEBE purr!!
92 325is
Now living in Sunny West Palm Beach FL!
Old 02-05-2008, 11:21 AM
Tired Member
DaddyGlenn's Avatar
How is the seating height with the Hunsakers? I am in the same situation, daily driver with monthly AX but I need to get an inch or two more head/helmet room.
Glenn
Daily Driver - '78 911SC RoW
Endurance Racer - '85.1 944
Street/Track Project - '86 951
Race Project - 944 Spec
Old 02-05-2008, 11:45 AM
No issue of height in my cab. They definitely sit lower than stock. If you did a direct mount of the seat to the floor that would also help!
IslandmanFL
hear BEBE purr!!
92 325is
Old 02-05-2008, 11:50 AM
Tired Member
DaddyGlenn's Avatar
Cool! And did you need to order the brackets, too or can you use the Porsche sliders?
Glenn
Old 02-05-2008, 12:04 PM
Seats come with brackets but I made my own and used the porsche sliders.
Show me your after market seats!
IslandmanFL
hear BEBE purr!!
92 325is
Old 02-05-2008, 12:07 PM
The bolt pattern on the Hunsakers is narrower than factory. A wider base mount is needed.
IslandmanFL
hear BEBE purr!!
92 325is
Old 02-05-2008, 12:08 PM
Tired Member
DaddyGlenn's Avatar
Excellent! And I see from your referenced post that we are the same height and weight (6'3" @200lbs) so they should fit me just fine.
Glenn
Old 02-05-2008, 12:19 PM
Indeed! I've found them to be a great value and very comfy!
IslandmanFL
hear BEBE purr!!
92 325is
Old 02-05-2008, 12:21 PM
