austin552's Avatar
Question Tach Troubles
All connections are good on the gauge. No movement when running. PO swapped motor so something may not be connected. How and where should I trouble shoot?
1974 911s
Old 02-03-2009, 12:06 PM
Zef Zef is offline
THE IRONMAN
Zef's Avatar
Alt voltage reg...!!!?
1984 911 CARRERA RUBY RED TARGA
SW CHIPPED-BURSCH CATBYPASS
MONTY FREE FLOW EXHAUST
<IN GAS WE TRUST>
Old 02-03-2009, 12:11 PM
austin552's Avatar
Battery stays charged and motor fires right up. Tach doesn't work.
1974 911s
Old 02-03-2009, 12:27 PM
There are several posts on this subject (including mine here 2.7L to 3.0L Engine Conversion / Swap)
You'll need the engine appropriate tach and I think you'll have to do some wiring.
Depending on how the rest of the wiring is done, myself or others might be able to comment on how to wire the tach.
Old 02-03-2009, 12:35 PM
austin552's Avatar
Thanks Rick but it was my understanding that a mid year tach would work with an early motor.?
1974 911s
Old 02-03-2009, 01:39 PM
Ok, well then I can't comment specifically to chassis that's now hosts an earlier engine. I assumed (wrongly) that you went to a bigger and/or newer engine.
Hope others can chime in who have similar experience.
Old 02-03-2009, 01:52 PM
austin552's Avatar
"I assumed (wrongly) that you went to a bigger and/or newer engine."
That is in the works also...
1974 911s
Old 02-03-2009, 02:25 PM
Man, I spend too much time searching this forum.
Hope this helps.
Tachometer Compatibility Chart
Old 02-03-2009, 02:40 PM
