p914's Avatar
Porsche Crest Supercharger for 914
Yeah ya can't turbo a 914 so they say. What about someting like this?
http://www.electricsupercharger.com/
It can be attached to any practically any car. My concern would be how much hotter would the engine run?
Old 06-11-2003, 01:48 PM
unclerichy's Avatar
Doesn't George Forman sell those on TV???
Rich
'73 1.7
'74 2.0
Old 06-11-2003, 01:52 PM
tat2dphreak's Avatar
no it's the other guy that sells fast orange or one of those cleaners... I would have to see it work 3-4 times before I would consider it... the 914 is not one of the cars they think of when building these products...
'72, now with a living, breathing 2056...
Old 06-11-2003, 02:01 PM
dave blackburn's Avatar
http://www.v8914.com/
Here you go!!
75 1.8L
Old 06-11-2003, 02:03 PM
david914's Avatar
Two words: IN - SANE!
David Dryden
'86 911 Coupe
'05 BMW X5 4.4i
Old 06-11-2003, 02:21 PM
M. Hendrix's Avatar
I have the one Hampton Bay makes, got it at Home Despot.
M
I wish I had a dime for every penny I ever had.
http://www.914club.com/bbs2/uploads/blog-1136350347.jpg
Old 06-11-2003, 02:37 PM
Rouser's Avatar
Send a message via ICQ to Rouser Send a message via AIM to Rouser
Garbage.
Money better spent elsewhere ... like maybe an eRAM'd blender!
Rouser!
Old 06-11-2003, 03:17 PM
mike mueller's Avatar
It should work as advertised...no difference than ram air used on the old muscle cars.
The key thing with the eRam is it only being used and functional at WOT.....not too practical for the street unless one really nails the throttle all of the time.
I'd say it would be one of those items to be added once everything else is done to the limit.
'73 914, 1.7, with Boxster transmission in the future?
Old 06-11-2003, 04:17 PM
p914's Avatar
OK..Who here does not run WOT all the time
Old 06-11-2003, 05:47 PM
canna change law physics
red-beard's Avatar
Mike -
When the big long thread occurred on the eRAM on the 911 board, I tried to reason with the guy. But he had not data to back up anything he did. The strip charts he had for the dyno runs showed an increase of the same delta "HP" from 0 rpm up to max RPM. This wouldn't happen with the setup he describes, which says to me they were fabricated.
Plus, all he ever talked about was pressure. Pressure is meaningless. Mass flow is meaningful. He had no data showing a difference in massflow.
James
James
Red-beard for President, 2020
Old 06-11-2003, 06:27 PM
p914's Avatar
Originally posted by M. Hendrix
I have the one Hampton Bay makes, got it at Home Despot.M
I couldn't get enough headroom with that model in the cabin! I wanted to... I really did.
Old 06-11-2003, 06:49 PM
Thats one of the dumbest things I've ever seen. No offense, but thats just a bit goofy.
Old 06-11-2003, 09:22 PM
p914's Avatar
No offense taken. Maybe modify gas powered leaf blowers and use them instead of electric motors
Old 06-11-2003, 10:06 PM
M. Hendrix's Avatar
You have to mildly roll your car to make it fit.
It's not for everybody, but since I run @ WOT..
M
Old 06-11-2003, 10:08 PM
Administrator
Dave at Pelican Parts's Avatar
Send a message via AIM to Dave at Pelican Parts Send a message via Yahoo to Dave at Pelican Parts
The only independant dyno test of the e-ram that I've ever seen actually surprised me by showing a small increase of power at low RPMs. It showed a noticeable decrease at high RPMs.
Sounds to me just exactly like something that can provide some air pressure, but not enough flow for an engine trying to move a lot of air.
--DD
Pelican Parts 914 Tech Support
A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling
Old 06-12-2003, 07:35 AM
Unregistered
sammyg2's Avatar
Ok, who's going to be the first to hook up a gas powered leaf blower to the intake and have the throttle hooked up to the gas pedal?
Just in case anyone needs incentive, .....
"you can't hook up a leaf blower to a type four"
Old 06-12-2003, 10:33 AM
no leaf blower needed... just wire an oscilating fan up to the battery!
Old 06-12-2003, 01:11 PM
Unregistered
sammyg2's Avatar
Tell me if I've been too close to the fumes, but a small gas powered leaf blower is powered by about a 5 to 7 hp engine, right? Seems like that could put out some air flow. Probably not more than a couple pounds of pressure, but that would be a change from around 2"hg intake manifold vacuum at WOT throttle to positive 2 psi? Should be good for 30 hp.
hehehehe.......
Old 06-12-2003, 02:02 PM
slowlane
Guest
Posts: n/a
5 to 7 hp leaf blower? is it self propelled?
Old 06-12-2003, 02:09 PM
M. Hendrix's Avatar
ROFLMAO Sammy!
I doubt you could pass emmisions by introducing a 9.8 CO reading on the intake, you crazy driving banana... who wants to calculate that?
I just stacked up 10 of those Tornado intake spoilers.. good for about 600 horses.
M
Old 06-12-2003, 02:43 PM
