Shaun @ Tru6's Avatar
Help: Turbo master cylinder mounted in early car
I am running Turbo brakes on the 73 track car project and need help in locating/mounting the master cylinder/servo unit.
Does anyone have info on mounting the unit? Clearly some sheet metal needs to be cut. Does it need to be reinforced?
Pics? Dimensions? Do's and Don'ts?
Shaun
Tru6 Restoration & Design
Old 05-10-2004, 01:52 AM
Licensed User
Shuie's Avatar
Ive never done it myself, but when I was researching this I found more than one suggestion to cut the complete section from a turbo car. Good luck!
Old 05-10-2004, 02:56 AM
Do a search. Someone did a nice job with pics a couple years ago.
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 05-10-2004, 05:14 AM
Irrationally exuberant
ChrisBennet's Avatar
Steve Timmins has a nice writeup. See http://instant-g.com/Projects/BM/Brakes/index.html
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
http://members.rennlist.org/messinwith911s/
Old 05-10-2004, 05:40 AM
best to graft in a donor section from any power brake car. there's also a outward hump behind the fuel tank that is part of the power brake sheetmetal, that has to be installed to allow clearance for the later pedal assembly. the donor section is trimmed down as small as possible to include the top section with the dip, and the reinforced front hump, as a unit, and carefully fitted, and butt welded. one of the metal tank vent lines thru the tunnel can be used for vacuum.
206 637 4071
Old 05-10-2004, 08:24 AM
Bill Verburg's Avatar
The easist path is to use a 23.8mm non boosted ATE m/c. Its an easy bolt in.
Bill Verburg
Old 05-10-2004, 02:59 PM
Thanks everyone for the responses. 3 unique solutions. The Al plate looks like a good compromise, but simply plugging the unboosted ATE into the stock spot seems like the easiest way to get this car on the road by mid-June.
Bill, do you know where I can get one of these?
Thanks guys.
Shaun
Old 05-11-2004, 06:04 AM
I think the non-boosted 23mm is sometimes referred to as "the Mercedes M/C" if that helps.
-Chris
Old 05-11-2004, 06:21 AM
Licensed User
Shuie's Avatar
part number for the the nonboosted 23.8mm master cylinder, aka the 23mm mercedes truck m/c (got it from an old post):
ATE # 3.2123-1003.3
Old 05-11-2004, 06:37 AM
Thanks guys, this board is truly the best!
Old 05-11-2004, 06:44 AM
pretty damn hard pedal with the 23mm and turbo calipers. just doesn't have the "feel".
206 637 4071
Old 05-11-2004, 08:16 AM
I disagree I have 993 calipers(even bigger pistons than turbo) and the non boosted 23mm. Feel is the best part, it does require more leg than stock but modulation is superb!
Old 05-11-2004, 08:47 AM
The non boosted m/c w/ 23.8 mm & w/ 930 calipers has a master/slave ratio of 16.539
If you have ever driven a turbo w/ the power assist disabled you know what this feels like, it' not that bad. For most of the past 6yrs I used setup w/ a 16.171 ratio, modulation is outstanding and most racers that have driven it seem to desire the same for their own cars.
stock non boosted 911 is 20.656
The lower the # the more effort is needed but better control is provided in compensation.
If you go for the non boosted m/c buy a kit from someone like Steve Weiner at Rennsport Systems . There are 2 versions of the m/c one has the operating ports on the wrong side, Steve wil also supply the correct operating rod and a couple of plastic bits that make installation easier.
Bill Verburg
Old 05-11-2004, 02:52 PM
Thanks Bill. I ended up with the kit from VCI (Vehicle Craft) today. Complete kit: $195 + shipping.
http://www.vehiclecraft.com/Brakes/930_upgrade.htm
Thanks again for all your help.
Week 7 pics of the project ought to be up next Sunday. The big job will be cutting/grinding the rear control arms to accept the rear turbo calipers.
Looking forward to that.
Shaun
Old 05-11-2004, 04:07 PM
Shaun
When I " Van Gohged" * my aluminum control arms for 930 brakes it was a piece of cake. What are you using for control arms?
-Chris
* Vincent Van Gohg: french impressionist who cut off his ear
Old 05-11-2004, 07:04 PM
Chris, I've got 84 rear trailing arms.
What did you use for your artwork? grinder? Sawzall?
Old 05-11-2004, 07:44 PM
Hald's Avatar
Shaun -
A grinding wheel [stone] will quickly fill up with aluminum. I've used both a cut-off wheel and a rotary rasp with good success.
Mark
'77 Carrera 3.0
http://members.rennlist.com/hald
Old 05-11-2004, 08:12 PM
Like Mark said, a cutoff wheel takes them right off. I can't remember what I smoothed them up with. I have rotary rasps/burr and files so I probably did it with one of those.
-Chris
Old 05-12-2004, 03:03 AM
