Big Red Brake Kit Upgrade
Question to all,
I have recentlly purchased a front brake kit for my '77 Porsche 911. Kit consists of 993 Big Reds and caliper adapters. Unfortunately the rotors were not included. Here's the challenge...is there an O.E.M rotor that will fit the offset of the standard hub and is also 12.75"? Has anyone done this conversion with an O.E.M rotor?
Old 10-27-2004, 06:01 PM
yes, but it costs$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
porsche only stuff. I believe 80 and 81 930 2 piece rotors.
Get the rotors and hats from Vehicle Craft incorporated
973 366 6577
76 930, copper bronze, mostly restored. ghl, k27,tial, big yellows, garretson i/c, for sale
Old 10-27-2004, 06:29 PM
MBruns for President
JeremyD's Avatar
yes, last I looked they were about $550 a piece
Lews930 - pm me your email and I'll make sure you are included in any tampa bay area porsche get togethers (we have a 2-4 a year)
Old 10-27-2004, 06:47 PM
and these are O.E.M rotors? damn!! I was quoted $650 for a set of domestic floating rotors and hats (msroadrace). So i guess that's the best price out there?
Old 10-27-2004, 06:52 PM
OEM = $$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$$
give VCI a call tell Doug your problem, he'll have the answer and super nice guy too
lewis
Old 10-27-2004, 06:54 PM
thanks Lewis, will do.
Old 10-27-2004, 06:57 PM
Send a message via Yahoo to Lukesportsman
Please report back your findings so that the archive may help others in the future. Good luck.
Luke S.
72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT
Old 10-27-2004, 07:01 PM
JeremyD's Avatar
I actually got some custom hats for my almost big brake project (993). Nice guy - great price
Dave Walsh, 301-748-7222, PRODIGIOUS Inc.
Busy weekend coming up - Brakes and such
Old 10-27-2004, 07:05 PM
if you don't mind me asking...what was the great price??? and where are they located?
Old 10-27-2004, 07:11 PM
JeremyD's Avatar
The kit included:
rotor adapter X 2
Caliper adapter X 2
Caliper adapter bolts X 4
Caliper bolts X 4
OEM 1998 993 Front pads w/out sensors X 1
NAS bolts, K-nut rotor mounting X 16 each
UL-32 Directional Vane rotors 309mm X 32mm X 2 each
Total: $415 plus Shipping
GT Directional Vane Gas Slotted rotors 309 X 32 X 2 each
ADD: $235
I opted to up to the GT Directional Vane Slotted rotors - these are wilwood and the version they use on NASCAR.
Old 10-27-2004, 07:27 PM
309mm??? Should they not be 322mm?? I'm not great in mathematical conversions, but i thought 12.75" rotors were needed with Big Reds??
Here's an article from Porsche Club of America. I'm confused by this...he mentioned the option of non-floating rotors.
"For rotors, some can be a direct replacement, and others require a hat to fit the rotor to the strut. In our example, the 930 rear rotor is a direct bolt-on to the 911SC . The stock Porsche 930 rotor has cast-in holes, which are much better than drilled rotors, and there are vendors offering slotted rotors also. The front rotors are a bit more complicated, as they must fit the 1978-1980 930 to fit on our 911SC. These models used a floating rotor setup where the rotor floats between two hats connecting it to the hub. You don't have to get the floating rotors, you can also get non-floating rotors. For street usage, the non-floating rotors will work fine, and will be quieter. At the other extreme, for pure track usage, the floating rotors are better, as they allow some rotor play for better brake performance."
Old 10-27-2004, 07:58 PM
disband
juanbenae's Avatar
two words, one name, bill verburg. do a search for his name here, he is the brake guru.
Old 10-28-2004, 08:11 AM
JeremyD's Avatar
Sorry - Mine are not big reds. Mine are 993 calipers (S4)and I need them to fit in 16" wheels - which big reds will not!
And yes, Bill Verburg is the man when it comes to brakes.
Here you are asking about sources for custom hats and rotors to fit your big reds - Try VCI - try the guy that I gave you, Try Steve Weiner - Here are a few links
http://www.pelicanparts.com/MotorCity/wmv/brakes.htm
http://www.rennsportsystems.com/
http://www.vehiclecraft.com/
Old 10-28-2004, 09:48 AM
Bill Verburg's Avatar
yes, if you have a true Big Red(not a 993 painted red), then, a 993tt 2 piece rotor on a custom hat works fine. These are 322x32mm or roughly 12.67" x1.25". These rotors are almost cheap(~$150ea) last I looked(but I hear prices have been soaring lately)
This is what it looks like
In the back the parking brake portion of a 993tt rear,322x28mm, is modified to accept the stock 911 parking brake setup.
These full kits are available only from Race Technology, the NA distribution arm for Brembo.
Bill Verburg
Old 10-28-2004, 12:57 PM
efhughes3's Avatar
Jeremy-I'm going down this same path-calipers from 993 are ordered. I'll soon be getting te rest of the kit from Dave @ Prodiguous. How do yours do for you?
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 06-25-2005, 08:00 PM
Location: member Central PA Region PCA , Home of the Hershey Swap
Not to hijack the thread, but Bill does you wife always let you park the Porsche on her rugs. Heck, I have to take my shoes off outside!!!
lol
Frequent Pelican Customer
1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more
2002 996 TT X50 (H&R Springs)
2002 WRX in WRX Blue
Proud Rennlist Charter Member
Support and Join Rennlist.com
An Expert on absolutely nothin' more than my own opinions!
Old 06-25-2005, 08:29 PM
Adrenaline Junkie
Hayabusa's Avatar
These full kits are available only from Race Technology, the NA distribution arm for Brembo. [/B]
Do you have a link to 'Race Technology', Bill? I found a company in the UK that does data-logging. I wasn't sure if that was it?
Old 06-26-2005, 01:11 AM
JeremyD's Avatar
Sorry Ed - never saw your post. My brakes have 4 DE's on them. Last weekend me and my buddy from Texas both drove my car - and it was 100 on the track. Still going strong. Combined with Motul 600 fluid - I have been very happy with both the kit - and everybody said the rotors wouldn't last - they have and I have been hard on them
Old 06-26-2005, 05:58 AM
Adrenaline Junkie
Hayabusa's Avatar
Bump for the link to 'Race Technology' ??
Old 06-26-2005, 11:46 PM
The kits sold here and most other places are Race Tech kits
but anyway
Race Technologies
Bill Verburg
Old 06-27-2005, 04:00 AM
