Sheared Alternator Shaft
Just driving along at about 2500 rpm in 2nd when she decided to detonate.
Credit Drago for the Photos Sorry guys Wheels declined on the photo shoot
WOW, that must have sounded bad when it let go.
John Adams 1980 ROW 911SC |
Definantely woke me up as I was out for a nice leisurely drive around the lake. Sounded like a massive backfire.
Light,Nimble,Uncivilized
That'll buff right out.
Oh, and I hear you can just use a little dab of JB Weld to put those blades back on.
Drago '69 Coupe R #464 |
Musta been the heat..
Wow, that is crazy how it just trashed the fan like that. Yikes.
Rob 1980 SC - 2011 Tiguan - 2018 Tesla M3P |
Registered abUser
wow... pretty catastrophic from an alternator's point of view. Must have some kind of major stress on the alt shaft for it to shear off like that.
Perhaps the front alt bearing has been seized/dry for a while causing metal fatigue from heat. That would be the load bearing area that would be stressed by the belts. |
When I told JW about it he said he hadn't seen that before. But he has since talked to gerber and they've seen it a couple of times |
Has JW commented on the lower pulley damage yet?
Registered abUser
yeah, I don't see any blueing on the broken shaft.
Perhaps the broken alt shaft is a result rather than a cause. If one of your fins suddenly broke and went around the pulley causing the belt to overstress the shaft...... we'd better call Columbo on this one. Ahh..... just one more thing, sir.
Oh the Humanity.!!!!!!!!!!!!!!!!!!!! Worse than the Hindeburg....
If it doesn't leak, you're out of oil. If you took a picture of a Porsche and put it in your shirt pocket it would leak oil on your shirt. Screw Flanders.... I'm goin' to Moe's. |
Lucky the fan shroud and the belt held the fan for a bit, lest you have a new air opening in your hood.
Damn, sorry to see that. Was the belt set right?
John F. Lewis 74' 911S Targa + 930/02 76' 914 - Eternal Type IV project FOR SALE |
Yes. The belts where recently adjusted. |
The photos don't have the fracture surface in as sharp a focus as some of the other parts, but if what you see is what there is, this looks like a sudden failure. Typical shear or bending failures of rod-like parts (bolts, axles, shafts) show a kind of "waves on a beach" or "half a tree-rings" which look like they start at a point on the circumference of the shaft, and then have semi circular rings getting larger and deeper into the shaft as successive stress cycles broke a bit more and a bit more, etc. Sometimes you can see rust on the outer and earlier parts of this growing fracture. Sometimes those parts are polished. Then there is a pebbly, grainy area which all looks the same as far as surface characteristics are concerned. That is the area which finally just broke all at once, rather than bit by bit.
If so, that would be one clue supporting the "fin broke first" hypothesis. Still, that is a thick steel shaft and some of us know from trying to tug on the fins how weak they are. Walt Fricke |
What your describing is exactly how the break looks...very uniform and grainy. Still, I have a hard time thinking that one weak blade breaking off would cause a ~5/8 inch steel shaft to fail.
Senior Member
Wow - besides being expensive that just looks spooky
78 Euro 911sc Targa 03 Hayden SCWDP |
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
