Drilling holes in concrete?
I need to drill 2 (maybe 4) holes in concrete and install some nuts so that I can bolt and unbolt stuff. The bolts will probably be 1/2"
What's the best way to accomplish this? What's the best fastener to use that's easy to install and remove?
Old 05-04-2006, 12:05 PM
vash's Avatar
Re: Drilling holes in concrete?
wow, that is kinda big. our contractors do this all the time. if there is repeated bolting and unbolting, they epoxy in threaded fittings. you will need one of those big, cool bosch hammer drills.
if you are going to leave it, they use this bolt that looks like a big sheet metal screw. just predrill and rattle it in. doesnt do that great once you take them out.
poof! gone
Old 05-04-2006, 12:11 PM
greglepore's Avatar
A good hammer drill is the tool of choice, with the appropriate bit-Hilti is one of the best.
I'd probably epoxy the nuts in place - there are structural epoxys for this sort of thing.
I'm assuming this is to tie down molds or something rather than pulling w/ a portapower or like, as you need serious anchors set in the crete for that sort of thing.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 05-04-2006, 12:12 PM
I'm with Bill
Jims5543's Avatar
What is the "stuff" that will be bolted and unbolted?
1978 Mini Cooper Pickup
1991 BMW 318i M50 2.8 swap
2005 Mini Cooper S
Old 05-04-2006, 12:19 PM
I bought a tubing bender, and need a way to mount it. I don't want it to be permanent, but it has to be reasonably strong while I'm using it.
I pulled the 1/2" size out of my cloaca; I don't think they have to be that big, but that would definitely be strong enough.
Old 05-04-2006, 12:22 PM
Dog-faced pony soldier
Porsche-O-Phile's Avatar
Floor/garage type slab or something structural? If structural, you need to be careful to not hit any rebar. . .
Black Cars Matter
Old 05-04-2006, 12:24 PM
Primarily reptiles, amphibians, and birds have cloacas. I'm sure if we asked some of the ladies that you've dated they'd say you were a snake, but....
Old 05-04-2006, 12:44 PM
I'm with Bill
Jims5543's Avatar
I would try the epoxy thing first. If you will be applying a lot of leverage to it I woul dthink you might have to do something stronger.
2005 Mini Cooper S
Old 05-04-2006, 12:57 PM
disband
juanbenae's Avatar
you can rent a hammer drill from most rental places. if this is the concrete slab you poured with-in the last couple years you may be able to get away with just getting one of those concrete drill bits that go on a regular drill. if you decide to use one of those i would use a garden sprayer and water, or the like to cool the bit while drilling. if not you will cook one of those bits before you finish the hole. expoxy and all-thread are good, or you can use a "redhead" type expansion bolt.
whatever you use can be cut off flush with the concrete (with a sawzall) should you eveer want to move the thing, or you sell the property.
Old 05-04-2006, 01:09 PM
Dept store Quartermaster
lendaddy's Avatar
Toby gots it (though you need not worry about water for a couple holes). I've done hundreds of these things to secure equip in our factory, it's simple and they work. Hammer em home
Cornpoppin' Pony Soldier
Old 05-04-2006, 01:19 PM
Sounds good, except I will need to use a female fastener, so I don't have something sticking out to trip on when I'm not using it
Old 05-04-2006, 01:22 PM
Seldom Seen Member
Burnin' oil's Avatar
If I was Thom, I would have a witty reply to that.
Old 05-04-2006, 01:43 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
Thom's not the only one tripping on his ***** around here....
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 05-04-2006, 01:48 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I just did 3/4" holes in a slab for securing a electric gate motor down. Rented a Milwaukee hammer drill from Home Depot and had it back in a couple hours. I used anchor bolts to secure it. Just hammer them into the slab. Holds a 150lb gate motor with a chain driven 3000lb load just fine.
Old 05-04-2006, 02:29 PM
vash's Avatar
yea but that isnt removable.
thom just use that two part epoxy and glue down some threaded couplers into some drilled holes. then you can counter sink them a bit, to leave a bolt in them even if the tool isnt connected. keep the dirt out. the downside is that you will have to drill a big hole to accomodate a .5 inch bolt. hammer drill time. it will cut like butta.
poof! gone
Old 05-04-2006, 02:35 PM
Gon fix it with me hammer
svandamme's Avatar
Hilti's rule when drilling in concrete
no need for water cooling the bit or what not
those buggers cut through like a hot knife through butter
Stijn Vandamme
BIMDIESELBMW116D2019
Old 05-04-2006, 02:44 PM
Where is that wrench?
EdT82SC's Avatar
I bought this one from Sears for $60 on sale. Cut through cinderblock like butter.
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00910116000&subcat=Drills
Ed T.
1982 911SC
Porsche Wallpaper
Old 05-04-2006, 02:56 PM
elwood-914's Avatar
Use a drop-in anchor, you have to drill the same depth hole as the anchor (so it sets flush) and you need a setting tool. You pound the setting tool with a hammer to expand the anchor.....there you have a female insert for bolts that is flush with the floor. I have used 1/4", 3/8" and 1/2"
1973 green 1.7
1973 Orange 2.0
1989 Ford F-150
Old 05-04-2006, 03:09 PM
Control Group
Tobra's Avatar
rent a hammer drill
Old 05-04-2006, 04:26 PM
Registered abUser
TerryH's Avatar
I agree with Elwood here....
This is what you need to have female threads for anchoring your bender. I've installed these about 1000 times when I had a real job. You can pick any thread size you want.
http://www.confast.com/products/drop-in-anchor.asp
'81 911SC Coupe SOLD
Old 05-04-2006, 04:58 PM
