Scan Codes P1189, 1188
I keep getting the following codes when my check engine light comes on: P1189 and P1188. I have changed the following parts: oil, oil filter, air filter (from stock to K&N), fuel filter, O2 Sensors pre cat, and spark plugs. The 323I has 98,000km. The car runs fine, no hesitation or rough idle. Every time I clear the codes, the check engine light comes on again but never at the same interval.
Anyone have any suggestions? Thanks
Joe |
Can you get ahold of another code scanner? Some times I use my onboard scan and then use my Peake scanner. Just to make sure.
318i Convertible, 5speed, 125k |
codes
I did and it gave the same codes. It was a snap-on tools scanner. any suggestions?
Joe |
So what do the codes mean. Don't make us look it up.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
1188 - fuel control bank 1 sensor 1
1189 - fuel control bank 2 sensor 1 Where are these sensors?
Joe |
I did some searching. The code is from the precat O2 sensors but not necessarily because the sensor is bad. Most likely it is a problem in fuel delivery.
You've already replaced the fuel filter. Other repairs I've seen were MAF sensor and Cyclone Separator or general vacuum problem. http://tech.bentleypublishers.com/thread.jspa?forumID=69&threadID=2917&messageID=9430#9430 Blindly replacing the cyclone separator would not be a bad idea, they tend to fail at 70-100k. I would test the MAF and check for vac leaks. You can probably find more info on the web. I only spent about 10 minutes searching.
Re: Scan Codes P1189, 1188
I had the same codes on my 96 328i. Corrected them by swapping the O2 connections on top of the engine. Seems as if i connected them wrong when i changed out the old O2 sensors.
Bill |
thanks for all you input and help. It ended up being the crankcase breather valve and hose.
Joe
Joe |
Goes to show what we know. LOL
Wait.. The crank case breather valve IS the cyclone separator.
I wanted to add a footnote to this thread as I spent almost 6 months fighting P1188 and P1189 codes.
Not until I stumbled upon Acegolf's note about swapping the O2 leads did I find a fix. Co-incidentally, we both have 1996 328i's. I just want to share this knowledge with the group as I spent hundreds of dollars replacing parts that probably needed replacing after 195k miles, but in the end, the simplest answer was the one thing that made the difference. |
