914-6 Factory Rear Brakes
Do 914-6 factory rear brakes have vented rotors? Thave 911 style parking brakes right? Don't they use 911 rear rotors? They are the best rear brakes to have on a 914 right?
VintageExcellence.com |
nope solid on the normal 6's
914/6 specific rotors some gts had vented |
Stay away from my Member
IIRC the only difference is a very slight increase in piston size. I can't remember if the pad is any bigger. Either way, from what I have heard, the improvement in braking is very tiny.
Some guys have fabbed nice setups using the 911 vented rotors and parking brake setup in the rear of the 914, but that was not a normal production 914-6 setup.
Chris C. 1973 914 "R" (914-6) | track toy 2009 911 Turbo 6-speed (997.1TT) | street weapon 2021 Tesla Model 3 Performance | daily driver 2001 F150 Supercrew 4x4 | hauler |
914/6 rears are similar to 911 rears
38mm pistons, larger pads can be converted for venting with spacers details are available
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s Addicted since 1975 |
914 Geek
Uhm... They are a lot more similar to the 914-4 rear calipers than to the 911 ones. The whole odd adjuster bit, the mechanical actuation of the inboard piston, the overall size and shape. About the only difference, really, is the size of the piston.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Where do you get the spacers?
Never enough time to be doing the fun stuff. '70 914-6 2.2 MFI #269 '71 914-4 2.0 '85 911 Carrera |
Not sure if the original factory spacers are available anymore. This is what I did
http://www.phoenixhobbies.com/html/brakes.html |
914 Geek
You get them from early 911 calipers. Some of the very early 911s with vented rotors used the same calipers as the earlier ones with solid rotors. But a spacer was used in between the caliper halves. This spacer works on 914-4 or 914-6 rear calipers as well. The O-rings are hard to find, though.
--DD
If your looking for 914-6 rear calipers or rebuild kits there the same as a ferarri dino rear brakes. My 914-6 rear calipers were leaking and I got rebuild kits from Ferrari. They also told me they still sell new rear calipers.
Steve 75 914-6GT clone with a 1995 3.6 DME motor, 915 trans with Martin Bott 916 shift kit, MB911 heat exchangers, boxster brakes, etc... Special thanks to Patrick Motorsports for fixing my 915/916 trans and there associated 3.6 conversion parts. |
canna change law physics
Now _THAT_ is a tech Jewel!
James
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
Check this thread for additional O-ring info:
Caliper painting The part # is 901 351 928 10 for a single O-ring. $1 per O-ring. Best, Barry |
O-ring update. Pelican has these, I just ordered 8 of them today.
$1.08 each. later, Barry Last edited by Barry2; 03-03-2003 at 10:48 PM.. |
