Eduardo Castrejón Elbjorn's Avatar
Send a message via ICQ to Eduardo Castrejón Elbjorn
Post 9 " X 15 RSR WHEELS backspace or offset ?
I need help with this:
I recently converted my 914 to 916 look then I need wider wheels.
My problem is at the rear because I want 9"
Please tell me the backspace or offset of the 9 x 15 fuchs wheels.
I received an e-mail from wheelenhancemnet and told me that the offset of this:
9X16 15 mm
8X15 10.6 mm
9X15 ?
8X16 ?
If aprecciate a lot if somebody tell me the difference between backspace and offset ?
Old 11-05-2001, 08:45 AM
Post
8 x 16 is the same offset
backspace = is the distance from the back lip of the wheel to the mointing pad of the wheel.
offset = is the distance from the center of the wheel to the mounting pad of the wheel.
Old 11-05-2001, 09:41 AM
Post
Hi Eduardo,
ALL Fuchs rims, with the exception of the 9X16 and the 7X15 type 911R have 120mm backspacing.
From that you can determine the offset.
For a 9X15, it should be about 3 to 5 mm.
I hope it's correct, but I think it is.
Regards, George
Old 11-05-2001, 12:14 PM
