Go Back   Pelican Parts Forums > European Car Forums > VW/Audi Technical Forum
Bobby (guest)
Guest
Posts: n/a
What do you think about using acetone or rubbing alcohol to clean the intercooler?
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-21-2013, 04:51 AM
Nick at Pelican Parts's Avatar
No, do not use anything like that. When you use caustic cleaners, there will be residue that could get into the engine afterward and create an issue.
If you want to clean it, use dish detergent and warn water. Start at the inlet and clean in the direction of air flow. You can tap or chake it to move dirt around. When done, flush with clean weater. Then dry using low pressure compressed air. Make sure it is dry before reinstalling it.
- Nick
