Go Back   Pelican Parts Forums > European Car Forums > VW/Audi Technical Forum
dorschman's Avatar
2006 A3 3.2 A/C question
I fee like the A/C is pretty slow to blow cool air compared to other cars. I put one of those cheap gauges on it today after letting it cool for a few minutes and got 35 psi at an ambient temp of about 80 degrees. Does this sound right?
Once the air starts cooling it does blow cold- it just seems to take forever to blow cold.
87 911 coupe "Katy"
Summer Yellow
Linen Mahogany interior
04 Pilot "The Pilot"
Old 03-18-2016, 01:45 PM
Administrator
Luccia at Pelican Parts's Avatar
May have a compressor on its way out. Some good info from a poster below:
I had the A/C in my wifes A3 replaced 3 times COMPLETELY all 3 times under the CPO Warranty. The system taking awhile to cool is a key indicator that the compressor is starting to go so I would have it fixed now as mentioned above the metal contamination results in your requiring a new Dryer, etc and increases the cost by another $ 600.00.
You can usually take a look at the compressor and determine which one you have as there is one in particular that was defective from factory. I know Audi had a TSB out on the Compressor for awhile.
If needed:
Quattro compressor - 2006 Audi A3 Quattro Base Hatchback - Air Conditioning & Vents - Page 1
FWD compressor - 2006 Audi A3 Base Hatchback - Air Conditioning & Vents - Page 1
Old 03-24-2016, 12:52 PM
